Motor alignment
Thelightskinlife
Hi I'm new and just got a go kart dirt cheap from a guy who had it just setting. I have a mini bike and was told I could put the motor from it on this go kart frame. The frame is a sodi but idk what model. I tried to look the frame up and it seems to be a belt that drives the axel. So if I buy a hub and sprocket can I still run this kart. Additionally, does anyone know the axel size 1.25 or 1inch? Also it seems counter weight are on these karts which I don't have. A picture is added to show the situation.
1" axles are the most common in the US
1.25" axles are less common but still well known to US karters of course.
especially on chassis like yours.
race chassis alike in europe run 30, 40 or 50mm axles instead..
since 1.25" are 31.75 mm and thus close to 30mm...
use proper calipers for measurement.
it might be a 30mm axle not a 1.25" one (~1/16" difference)
you need a clutch and an axle hub and sprocket.. then sure you can run that kart
(chain or belt as you prefere.. chain much cheaper, belt much quieter)
assuming you got the proper gear ratio going.
is the engine modded? if so what mods have been done? (to estimate the needed gear ratio)
Thelightskinlife
Thank You, you are right on it's 30mm I got a dial caliper from home Depot...I was def off...I'm sending the stuff I ordered back this morning by fed ex. The motor has a bigger jet, new air filter and different header. I'll eventually get to the springs but for now that all. Next I'll need some a tire the right rear has a side wall cut. Additionally, I'll need another key I measured the others they say 7mm. So it'll be about a week or two before I actually get it running .and man tires are expensive. And go power sports is taking 15% restocking fee so I'm taking a lose even sending the stuff back smh
SmokeyTheSodi90
Hey where did you (if you did) end up ordering wheels/tires from? I have a SodiKart GT5 and I am having the hardest time finding aftermarket wheels that fit our 30mm rear axle and 20mm front stub axles. Its nearly impossible to find a matching set of wheels.
Anyone reading this find a solution? I live in the US by the way, so most of the online suppliers dont ship to US..
FlyFrog
Kankakee Illinois
axel change and spindal change out you will be set
Thelightskinlife
I apologize I never replied but go powe sports is where I got everything
