Hebert1001
- Messages
- 3
- Reaction score
- 0
thanks, great infoHere's a good example of the 40 series without a backplate, you just mount the driver on your shaft and mount a 3/4" (my choice, use what size you like) jackshaft where the belt fits across the driver and driven correctly, see link below. I've used Jeremywell Industries a lot, really like them.
40 Series Torque Converter Kit Clutch Pulley 1" Driver 3/4" Driven 8 t – Jeremywell (jeremywellindustry.com)
3/4" Keyed Shaft | 400134-** | BMI Karts And Parts
UCP204-12 Pillow Block Bearing 3/4" Bore 2 Bolt Solid Base (2PCS) – Jeremywell (jeremywellindustry.com)
3/4" Bore Double Split Shaft Collar Black Oxide Set Screw Style (4 PCS – Jeremywell (jeremywellindustry.com)
Scroll to the bottom of the page on this link to read a good page about TC's. You'll pass a drawn diagram of a 40 series setup on the way down, very good guide...............Comet Drive Belts | Comet Torque Converter Belts | Go Kart Belts (gokartsupply.com)
