Robertominibaja
- Messages
- 7
- Reaction score
- 0
Hey everyone new to the forum and need a little help. I have a 196cc clone engine with the following done to it:
Remove governor
New flywheel
New mod2 cam
22lb valve springs
1.3 ratio rockers
Exhaust header
Intake
Bigger jet in stock carb (91 or .38 is the size)
Billet connecting rod
Torque converter
before I took the engine off to rebuild I had the centrifugal clutch and just the carb jet, intake, exhaust header, 18lb valve springs and the new flywheel with no governor. With this set up I could reach about 60km/h and about 6200 rpm under load. With the new set up above under load I can’t get it to go past 4000rpm but not under load she revs all the way up to 7500rpm easily. Anyone have any ideas why it won’t rev under load?
Remove governor
New flywheel
New mod2 cam
22lb valve springs
1.3 ratio rockers
Exhaust header
Intake
Torque converter
