Budc
I am a 77 yr old man who is building my first go kart ( wooden 6' long) with my 12 yr old great grandson that will be driven on asphalt and concrete 80 % and grass 20 % of the time.. I have a Harbor Freight Predator (212cc, 6.5hp, 4 cycle, 3/4" shaft, 3/16" keyway) engine for it. I plan to leave the governor on it.
Now I need help .... I want to buy 3 floater tire and rim assemblies, and one tire and rim assembly with sprocket .... what size tire and wheel would be ideal? Should front and rear tires and wheels be the same size? What type tire would be best? Would 10 /60 teeth on small/large sprockets be correct?
I plan to use the square tube/bolt method to mount front tires.... will that also work to mount the rear tires???
Any advice on what to look for when buying a centrifical clutch for our engine?
What # chain should I use - I've been told to use a #420?
I have made a wooden braking system that contacts both rear wheels - hope that was a good move!?
Do I need an metal engine adjustable mounting plate or can I slot holes in the wood frame?
Best way to install a throttle?
Where is the best place to get my needed parts? So many places online to choose from!
Anything else that you can suggest?
I really thank you so much for any recommendations and advice that you share with us. Thanks again.
P.S. (This old woodworker probably should have just purchased a completed go kart!)
