Are there gears with more teeth for the size 40 chain clutch? Im currently running 10t clutch and 54t axel sprocket. but i would like 14t clutch sprocket to go faster. Can I get a size 40 chain clutch with more than 10t? or buy a gear with more t?
my wheels/tires are about 7 to 8 inches top to bottom. and the kart tops out at 33/34 mph. its a street kart.
Im 32 but sheesh i just realized idk how to post pix. Im new to forums. How do i Post pix?
Bigger engines do not alone make anything faster. Bigger engines make more torque. More torque allows bigger tires and/or higher gears.
Small tires = more torque
Large tires = more speed
Short Gears = Low Gears = Higher Number Ratio (7.2 :1) = more torque
Tall Gears = High Gears = Lower Number Ratio (4.2 :1) = more speed
Higher engine RPM = more speed (regardless of tire size or gear ratio)
So if you slap a big engine on there with twice the HP, but don't change tire size or gear ratio, it is likely that you will go slower. The larger engine will probably turn less RPMs out of the box, so without changes you will go slower.
To go faster without changing tire size or gear ratio, you need more engine rpms.
To go faster without more engine rpms, you need taller tires or taller gears.
