Go Kart build for the grandkids
Rando
Decided to build a cart for the grand kids and give me something to do! Turned out to be way more of a project that I give it credit for. Built a lot of things out of wood in my life, but this was the first all metal build. Bought the plans for a spider cart, and started with the build till I started my own modifications. I wanted brakes on all 4 corners and wanted it to turn better than a solid rear axle cart. So I bought a Chinese parts group that included front upper and lower control arms, hubs and brakes. Rear axle with a diff and brakes. Also after researching cost of motors and torque converters, I decided to buy a ATV replacement motor with 4 speed trans and reverse built in. One thing about buying Chinese parts, no documentation or information on anything.
Rando
the build
Started with the plans as drawn, working in the bought parts, mocking up to see how it will work. Work on the front end geometry.
from the first photo in this group to the last, notice I had to refab the top shock location. cut and modify the steering rack almost to the point of no return. the unit I got was way to wide for this build. Width was set by rear axle and finding rims to go over the brake calipers.
Rando
3 pedal setup
Adding the front suspension assembly to the main frame and starting the cage
the engine selection made this a 3 pedal build
Rando
More build photos
More from the build. I have it completed, but now debugging. I have 2 items that are being redesigned. The gear shift linkage and the jack shaft. motor has too much torque for the jack shaft design in these photos
You have the motor independent from the swing arm.
The best approach with this rear end, would be to have the motor/jackshaft/swingarm all on a swingarm assembly.. they would move together unhindered and when setup right, a harmonious movement.
Rando
Final Assembly
Yes I considered that set up but was concerned with the shifting mechanism. All the bikes I owned over the years I noticed were sometimes difficult to shift with direct connection and your foot and the original design here proved it to be the same issue.
Final assembly, test drove and now in redesign of shifter assembly and jack shaft / idler assembly. Also have not been able to get the brakes bleed, even with compressor assisted vac system
Rando
Thanks
I suspect if it wasn't for this odd year that I ended up with a 5 week stay at home order from our Governor it still may not even be a rolling chassis yet.
Still pondering the redesign of the jack shaft and idler sprocket. Shifter mechanism I believe I have solved just need centering springs to finalize it.:cheers2:
diygokart
Hello! I can't afford to buy the plans for such a kart. I'm 13 years old, I know how to use a welding machine and cut metal. My dad agrees to help me build a Grand Daddy kart. But I really need the plans. Here is my telegram @i_like_diy. I would be very grateful if you send me the plans.
You forgot to tell us where to send the welder...
diygokart. Did you even bother to read post # 1. You have a VERY talented craftsman stating that it turned out to be a lot more difficult than he originally anticipated. I am not trying to be mean, but at 13 years old and not enough money to purchase plans you are NOT ready to take on a project this complicated
or costly. Save up your money and then start a search on Craigslist, Offer Up, and Face Book Marketplace. Find yourself a cheap ( they're out there ) beater kart that needs some work. Hone your skills and building abilities on something that already has the frame constructed. It will be a LOT cheaper than building from scratch. You are only 13. You'll have plenty of opportunities when your skill and economic situation are a little better.
