Cutting valve guides down-yay or nay?
Well I am elbows deep into porting my 212 Hemi head and that pesky, ugly, flow disturbance of a valve guide is in my way. I just want to cut and grind the crap out of it. I know that it's important to preventing valve stem runout and proper valve closure... and maybe it helps to dissipate heat from the valve and whatnot... but I want it GONE! Stupid valve guide.
So, what's everyone's thoughts, opinions, experiences? Leave it alone, trim it up to "x" amount, slice the puppy flush, what?
jamyers
Buffalo Gap, TX
I've never messed with a 212 hemi head, but I have messed with lots of automotive and other engines...
I'd aim for the middle ground - grind it (and the head around it) into as smooth a teardrop shape (when viewed from the valve face, and with the rounded part of the teardrop facing the upstream flow) as possible, leaving as much meat there as you can. Generally only the highest-rpm engines need the guide cut clear down, most engines will respond well with simple smoothing and contouring.
Thanks jamyers. That would be great if I could take some length off from it since I'm trying to produce the best quality air possible in these small ports that I'm trying to tighten up for more velocity at low valve lift. What do you think. Will there be much reliability in the aspect of valve stem runout if it's trimmed down before shaped? Keep in mind that this engine isn't going to see WOT at max rpm's very much at all. It's a low rpm torque motor build for use in a small yard.
I am thinking of picking up bronze valve guides for extra rigidity when I grind it down to prevent valve runout. It's only around $20 for 2 with shipping. Then I would feel better about it. What do you guys think?
65ShelbyClone
SoCal
What others have done is drive the valve guide flush with the port. Just be sure to check retainer clearance.
Thanks ShelbyClone. I think I will leave a bit out since I don't really need much max CFM. Have you heard of valve runout on a mild built engine with stock guides and valves at modest RPM?
65ShelbyClone
SoCal
It doesn't seem to be a topic of concern. Shorter guides tend to wear faster than longer ones over the long-term.
Here is the the hemi head from NR with full race port w/ bead bast finish.
The exhaust is taken all the way down.
https://www.nrracing.com/product-p/headhemi.htm
When I did a hemi head myself, I tried to keep the guides intact, but I ended up thinning them out a bunch. I was afraid the tip of the thinned out guide would crack or chip. I felt more comfortable with the guides flush (or almost flush), instead of having the 'now' thinned guides. If I was able to port around the guides without removing material from the guides themselves, I would have keep them as they were. I think some remove the guides before porting, then reinsert guides (I'm guessing new) after the port work is finished.
Thanks bobo. That's useful info. I round down the guide some and thinned the guide out a bit but left a good portion. I think it will work out fine. I'm not going for max flow so I tried to use it to help swirl a bit in an attempt to provide more even pressure through the valve curtain. I was in search of quality brass guides but I think I am going to see how these hold up.
Shouldn’t have to search hard if you want Bronze.
I know NR offers bronze 5.5mm guides for around $15/pair.
Thanks. Yeah, I found about 4 or 5 places that carry them. It's difficult to know the quality of bronze that are used to make them as well as the exact size they are. Some of them you need to hone out the guides, some you have to freeze the guide and heat the head while you put them in. Some people have been able to just tap the old ones out and new ones in. It's difficult to know what you might have to do. It seems like it might turn into a headach and more money spent than needed especially if I don't really need them. I am just going to put them off for now I think.
