Flyinhillbilly
The great cornholio
I’ve been putting off building this because I’ve been waiting on a head from a guy that I’m pretty sure has screwed me out of my $650 that I paid him six months ago. I’m trying to resolve that situation one more time, but I’ve decided to move on with the build since my daughter had to race with a motor I built from spare parts last weekend. She was up to 5th when her chain broke, but I know she can do a lot better if I turn up the woopow, so I’m turning it up to 11. She has a great deal of natural talent, and it’s time that I put her on something that doesn’t rely so much on momentum.
The foundation is a studded 2.835 Tillotson block, the rotating assembly consists of a 2.3 ARC super alloy stroker crank, 3.525 ARC billet connecting rod, and a Wiseco 2 ring forged piston that comes in at a .640 compression height. The cam is yet to be determined, and instead of the fully welded 34mm port Warhead that I was going to put on it i’ll Use the 96cfm Tillotson 32/28 head that Laid Back Racing built for me. The carb will be a 28mm flat slide on a mixture of 25% nitromethane and 75% VP M5. The flywheel will be ARC, and the coil will be genuine Honda. This will be topped by 1.3 rockers, and chromemoly pushrods, and it’ll all be closed up with an ARC billet side cover, and a custom billet valve cover from Mr. Valve cover.
I’ll post pics as I build it, and let you guys know how it runs. I’m hoping it’ll be pretty fast.
In this first set of pics, you can see that I’m going to have to clearance the block a little on the top side of the bore for the rod, it’s a little too close for my liking, you can also see the Cometic head gasket, studded Tillotson block, and all of that shiny ARC and Wiseco goodness. I threw a pic of the head in because I like it so much.
I’ll post more pics as I progess.
