Help me make it up the hill..problem 1
Jakemakeitupthehill
*Help Me Make It Up the Hill!
Hello, iv given it my best shot. I knew there was only one way to figure out what is wrong with my engine so I'm here. This is my introduction so I guess I'll save an extra thread by posting the reason I'm here as well.
Took a stock 6.5 lifan ( honda clone) and added after market air, a header, 22lbs springs, aftermarket dynocam flywheel, a bored to .650 carberator, along with a torque converter. Took out the rev limiter.
It will start but no matter what I do it will shut off when I try to hit the throttle. Now it is just having a hard time starting. Earlier before I added the torque converter I got get it to rev pretty high. Nothing is wrong with the torque converter far as I can see. Entire reason I did all this was because I cant make it up my hill. Bought it for me and the wife not to have to walk up my steep *** hill...the original wouldn't cut it at all ( predator 200 gsx.
Iv messed with the carb..alot..obviously I dont know what I'm doing.
Iv got a rod and a cam on the way but cant even get it to run at good enough as is.
Jakemakeitupthehill
By the way, I'm obviously not a super engine guy. I messed around with motorcycles and can do basic car stuff. I researched these forums and YouTube to get to this point. My wife is.gonna have my *** if I cant get this thing to get us up the hill. Iv got a duromax 18hp on the way with a series 40 torque converter along with an engine mount I can weld...fixing this problem is more a personal thing.
Did you re jet the carb and do a plug test to see if the jetting was good?...
Is the gov out completely, inside aswell??...
What is the gear ratio, and OD of rear tires... not sidewall size but measured from ground....
Brisketends
Corpus Christi, TX
My opinion, sounds like you are running rich. Try opening up the throttle when you start it. Kart will need to warm up a bit before that throttle response works. The fix might be to go with a smaller or stock jet. Aren't those carbs a #70 stock? You bored it .65 inches? mm?
Flyinhillbilly
The great cornholio
North West Arkansas
Check the gasket behind the carb, the bowl is vented through that gasket and it’s real easy to put it on wrong. Also, check the size of your carb insulator against your carb and see if you need to file it out to match the size of the carb.
On another note, you may look at your gearing and think about a lower ratio of getting up a hill is your main concern.
Karttekk
Elizabeth, PA
Agreed. A larger axle sprocket will lower the gearing and give the kart more torque for hill climbing. Too large of a sprocket may bottom out though so increase accordingly. You may need to add chain links with the larger sprocket.
Jakemakeitupthehill
Ok, so problem 1 solved. Yes it must have been running WAY to rich because I totally forgot to add in a spacer between the new carb and the engine. I'm assuming that the gas had no time to turn to a gas before going into the engine. I didn't even think of it till I saw a spacer I have for a mikuni I never bought. I rigged it on there ( very rigged) and what do you know rpms shot through the roof. Cant believe I didn't give it a thought sooner.
On to problem # 2. I have a duromax 18 on the way. Iv been reading and everyone is saying its marketed badly and really is only a 13hp motor, if I use it I'd put a series 40 on it. However I'm working on this little guy and got a rod and cam in the mail today....it should be sitting at maybe 15 hp after I'm done. What engine should I use? The 6.5 only has a series 30.
My sprocket is about 8" and has 47T. I have a 10T on the converter. My wheels are about 17" from bottom of rubber to top of rubber with a 9" wheel. I can only aford a 9" sprocket before I start eating dirt. Advice?
You currently have VERY bad gearing for your kart. You are sitting at 4.7:1 with 17" tyres. Definitely not ideal for anything other than a downhill. You are probably burning up your belt at a rapid pace.
You are either gong to have to get larger rear sprocket, or go for smaller tyres.
You say you have a 47T sprocket now.......and that 9" sprockets will make you eat dirt. That doesn't sound right with 17" tyres, spo could you please post some pics of the kart from all angles for us. It is hard to see from your pics that are all centred on the engine. Lets see the sprockets, wheels, entire kart, etc
Joe-405
Enjoying New Projects
U.S.A.
What landuse said of course.
And the duromax is a big block so it will always have more torque. And more than likely be more dependable for you and your wife since your not racing it and you got a “hilly” issue.
Jakemakeitupthehill
Good points guys. I'm having a hard time finding a sprocket that will fit my axle along with enough teeth. My axle.has a 2" bore with 4 bolts. I'm willing to go #35 or 420. Whatever I can find with the highest ratio that's about let's say 10" round. Any one know where I can find one for 35 or 40 that will give me a 10:1 using a 10t or a 12t?
But you say your tyres are 17"? You could easily get a sprocket with enough teeth on it and still not drag in the dirt
http://azusaeng.com/wp-content/uploads/2019/07/AzSDno40.pdf
Jakemakeitupthehill
As much as you need to lower the gear ratio, I’d probably be looking at adding a jackshaft.
I was kind of hoping I could avoid that but your probably right. I read an article on it and if I'm not mistaken I could go 10t to 40t jackshaft , 10t jackshaft to 40t rear and that will give me a 16:1 ratio? Or do I have that all wrong. Does jackshaft placement really matter or just where I can fit it in? Iv never tried to do a jackshaft so any tips are welcome. My Duromax engine comes today!!!
Jakemakeitupthehill
Ok...update...so I got the duromax today...and wow....way bigger than I thought. Put the new jets in, air done, header w muffler, removed the oil stop and rev limiter...had to line up both the balance crank and the cam..both fell out...changed the springs set lash...and now I'm worn out..I'll advance the timing tomarrow with a key 6*..how risky is it to run it like this with no billet flywheel?
---------- Post added at 11:57 PM ---------- Previous post was at 11:56 PM ----------
I'm really hoping I wont need a jackshaft...I wont have room..I suck at welding as it is..simple flux
---------- Post added at 11:58 PM ---------- Previous post was at 11:57 PM ----------
Please get back to me before tomarrow if I'm about to shred my stock flywheel
Flywheel isn't so much an issue as your con-rod is.. keep stock springs.. that will act as the gov to keep in the safer zone before the con-rod let's go..
