420cc Predator on a 2 seater atv
Turbeau
Need help with 420cc predator engine running bad. Recently got a frame with bad motor from one of my nieghbors and I had an extra motor off an air compressor with a bad pump. So after lots of welding and modification. Got it all lined up and the 30 series torque converter kit just too weak for the size of the kart. I did have to put an aftermarket exhaust and filter to get motor to fit. When one of my sons tried the first test drive engine wont idle right. Surges and dies at idle. Any help much appreciated
PullHorse
30 series is rated for 9 hp or below or around there. The driver usually also is 3/4" bore... how did you even fit it on the 420? You'll need a 40 series.
Any intake and exhaust mods lean these engines out more so than stock. All engines run lean to meet emissions. You'll need to re-jet the carburetor with a bigger jet to richen it. If you cannot find a larger jet (GoPowerSports sells them), get a carburetor jet drill bit set. Ones for an oxy-fuel torches will work, it's the same thing. Also, get rid of the 30 series for a 40 series. It's more expensive, but it should move it better.
You can get a 30 series with a 1" bore...
Yes you can, ive got one myself and it never made sense to me, 1" shaft from all the engines ive had start around 9hp so it's always going to fit an engine it's not rated for.
301 Predator, GX270/240 are at the top end of what it's rated for.
Smerft85
Southern Colorado
Mine is on one of the aluminum plates, it came on a gx390 I had, but with the plate it wont fit correctly on a big block, I'd still highly recommend keeping the 30 series on small blocks and step up to the 40 series for any big blocks. There is good reason my 1" 30 series has been on the shelf for almost a year, doesn't really fit anything.
