Thank you for the reply! Not much information out there on the cheaper converter performance aspect. FWIW I routinely saw 6500-6600 RPM on my 30 series this weekend. Its a mild build, doubt its more than 10 hp. 160 head, old 212, 22mm carb, exhaust, MOD2 cam and 34* timing. Lots of belt dust! First run is always the best. Heat and dust build up quick.
So what I don't get is why the 20 and 30 series would both be rated to 8hp? If the 30 can handle 8 with one side of the belt gripping the sheaves. Why is a belt gripping both sides not going to allow more power with less belt slippage? Is it the weights inside the unit? Would heavier fly weights in the driver grip the belt more tightly?
The 40 series unit weight a TON! More than my cast alum flywheel for sure. Not really meant for the 212. Or so I was told.
So what is it that provides the "grip" exactly. How can we modify it? Would heavier weights provide more force/grip at RPM? It's the only real difference I see on the 40 series aside from the V-belt.
Theres alot of talk about big RPM here. Yet when you go to the drag strip and listen to the JR dragsters with theri $1000+ clutches they basically stay at peak torque RPM the entire run and let the converter do the work. I'd have to assume this is the most efficient route for "Drag racing". So revving to 8-9k with a converter woudl be less than ideal. You'd want to set it up to hold your pk TQ rpm the duration of your race and have the sheaves slowly transition in the wheel speed.
Just a thought!
I'm tired of these clutch boys whoop'n my butt the last 120ft. I smoke most of them off the line.
