I've found the answer, I think
J.S.@SMS
Road Hazard
Weeki Wachee Fl.
I think I may have found the answer for putting lighting coils on a predator. This:
https://www.gopowersports.com/crankshaft-212cc-tillotson/
It's a tillotson 212 crankshaft, so I'd think it should fit in a predator, but it says in the description:
The KD212-1275 is the stock OEM crankshaft assembly for the 212cc Tillotson Engine (blue), with a 54.94mm (2.165") stroke. This Crankshaft accepts the clone/honda flywheels and connecting rods but has .040" more stroke then the 196/200's which makes this crank a cheap and easy way to produce more power.
So it accepts Honda and clone flywheels (according to GPS), which come with lighting coils.
you may still have no threaded holes to mount the actual coils in your predator.
the IMHO correct solution is to buy a rato p210-III with e-start
since that IS what HF sells you as a predator.. well with e-start of course and thus lighting coils ;)
J.S.@SMS
Road Hazard
Weeki Wachee Fl.
Now that has me wondering. I might pull the flywheel off one of my predators to see. But I remember that the low oil sensor mounting holes were tapped on my minibike which never had a low oil sensor (should be a rato if I remember). I have a non hemi that’s just sitting on a shelf that I’ve been meaning to re lap the flywheel on, since when I got it, it came on a kart that was sitting out in the rain without a muffler (there is a slight water stain halfway up the bore, but I can’t complain since it came with three karts for $300).
Flyinhillbilly
The great cornholio
North West Arkansas
I have one on my bench wit the flywheel off. The holes are tapped on my hemi. I haven’t paid any attention to any of the others I’ve had apart.
good to know..
I'm not sure if rato always had a e-start p210 or if that was a more recent addition.
but as long as 'some' are it's at least a chance..
Now all there's left to do is find a US supplier for rato spare parts I think
PS the first tillotson were Ducar engines IIRC.. a 212 Ducar with e-start isn't too hard to find
really so that's still a very easy solution as well
Smerft85
Southern Colorado
I watched a YouTube video of someone adding the coils to a predator, if I remember correctly it was the non hemi and it had the threaded holes just like that.
My concerns were most a matter of age than a mater of headshape ;)
I don't know if rato added e-start to their p210s recently or they always had an e-start 212 engine..
I know the p200 (196cc) always had an e-start option, I wasn't sure about the p210s
since there's little to no solid infos out there.
I'd say a fresh out of the box predator should be tapped... one you bought a few years ago... I have no clue!
So my best advice would be:
if you intend to try, take a quick peek under your flywheel just to be sure first ;)
txluke
Victoria Texas
Take the coils and flywheel from a clone and use them on a non-hemi 212. The flywheel taper is just slightly off but 5 min of lapping and it fits perfect. Don't forget to check and adjust your coil gap if necessary. I have done this on 3 different engines. The best source of coils and flywheels is off of a Baja warrior or Coleman ct200u-ex. People are always swapping predators on them.
