Valve Spring Bind
JTSpeedDemon
2019 Build Off Winner!
Texas
So I've heard a bit about valve springs binding around valve float rpms, but I haven't heard much except that it's bad and things break when it happens.
Since I've got the normal Raptor rod coming, I won't have to worry about rod throwing, so my next concern is the valve springs.
At ungoverned speeds with stock springs, do I need to worry about coil bind? Or is it only a problem with high lift cams?
What exactly IS valve spring bind? Is it anything to worry about right now? Or should I just pop in some billet lifters and call it good?
Otherwise, is there any harm to the valvetrain other than lost efficiency if I run the engine at valve float for a while?
BigWes
Alabama
Coil bind happens when you have enough cam lift to cause the spring coils to stack and touch each other...or in the case of float the same occurance.
If you have enough cam lift to cause coil bind without floating the valves then you have a mismatch of parts installed and will bend and break stuff. All coil bind should be considered a bad thing. Check your clearances at full lift it should give you an idea of what to expect.
JTSpeedDemon
Texas
I'll pop the breather cover and take a look just to make sure.
If it were running at valve float, would it be a possibility that the cam moght slap the valves, possibly causing coil bind at high RPM? Or am I overworrying?
Also the exhaust valve spring feels heavier than the intake, what's up with that?
wenee9w
Going to be tough to get coil bind with stock grind cam. I always ran 2 exhaust springs one on each valve and upper shims on a stock set up. That allowed it to wind up some. That was before slapper cams. The exhaust spring is taller there for adds tension to the installed height. The exhaust valve runs hotter than the intake allowing the spring to lose some tension due to heat soak.
JTSpeedDemon
Texas
So dual exhaust springs will act like heavier trick valve springs, allowing it to rev higher?
Otherwise, am I really risking anything if I run it at valve float?
wenee9w
Not dual exhaust springs thats a different animal. An exhaust spring on both valves. No not really risking anything, at the most a bent valve. But I never bent one on a stock cam.
JTSpeedDemon
Texas
Yeah that's what I meant. Need to choose my words more carefully.
I just popped open the breather cover(the bolts were a little loose, new lockwashers and proper torque specs are in order).
This is what I found. What does the 13 S mean?
It looks like I have valve retainers instead of pins, but it looks like the exhaust one is different.
Also, why is the exhaust spring noticeably thicker? Is that just how it is?
The parts manual says the exhaust spring is part# 26826, the intake valve spring is part# 690520(it's actually listed as an exhaust valve spring), and the thick exhaust valve spring retainer is part# 292259. Hope the numbers help in case they mean anything.
Oiling hole looks clear.
Also it looks like my intake valve spring is upside down????:huh:
Has the PO Bubba'd my engine?
Educate me on my valvetrain please.:huh:
BigWes
Alabama
I'm not familiar at all with that set up, but if you are running a stock cam then coil bind is something I wouldn't even worry about. You aren't gonna make enough lift to get coil bind. You might get enough to float the valves but when you hit that RPM the valve float becomes RPM limiting... problem solved. I think the 13S is just the block casting...I don't know the meaning. Exhaust valves run hotter so some engines will have beefier springs installed... maybe that is what we have here... Do some research before you assume it is wrong or right.
---------- Post added at 10:34 AM ---------- Previous post was at 10:33 AM ----------
I think you are overthinking this just a tad.
JTSpeedDemon
Texas
Yeah, but that's partially because I want near zero chance of this engine letting go at high RPM and screwing up the block.
I know, I know, there's always a chance, but I just want to minimize it.
Either way, I'm just curious about the valve spring setup. All of the other pics of flathead valve spring systems have two more or less identical spring/retainer setups. And no stamping in the back.
BigWes
Alabama
I'm curious about your engine as well, I'm wondering if it was some kind of old school industrial type small engine like maybe a heavy duty pump engine or something on that line. The orange paint has me wandering. Could it have been a pony motor for a hydraulic pump on a fire engine or other emergency vehicle in the past? We may never know what its history was. But I think it was set up as a duration and lugging engine verses a high RPM engine by the looks of that valve train...but that's just a guess on my part...but it's definitely a very interesting find you have for sure
---------- Post added at 12:50 PM ---------- Previous post was at 12:29 PM ----------
Holy crap JT, do you have any idea how old that thing is? My research just now puts it pushing 50 years old! Also used on generators... You may want to source something different to use...that thing is kinda different...
---------- Post added at 12:58 PM ---------- Previous post was at 12:50 PM ----------
JT, tell me if the link below is your engine...
https://www.partstree.com/models/100232-0514-xx-briggs-stratton-horizontal-engine/
JTSpeedDemon
Texas
No, that diagram is for a 4 HP. Very similar, but the crankshaft and piston are different parts-telltale signs it's not a typo.
I do have a 4 HP head, but the bore matches 130000 series spec. And the code starts with 13.
It's not 50+ years old, the serial number indicates it was built in 1985. Perhaps the design dates back 50+ years, but not this particular engine. Plus all of the model code on my blower housing matches the specs of the engine, plus the paint.
It may be setup for low rpm thumping forever, but it's governed at the standard 3600 RPM.
The back of the parts manual says "Service Note: For all Go-Karts use only a Model 136200 series engine as a replacement, regardless of the original Model."
So I think it was designed with certain features of the Raptor series engines as a long life, high performance(hi comp head) go kart engine. IDK.
I plan to run it on the kart due to all the unique features, but I don't want to kill it due to it's uniqueness. That's why I'm erring on the side of caution.
---------- Post added at 02:13 PM ---------- Previous post was at 01:32 PM ----------
I just sent a message to Briggs and Stratton asking why it was built the way it was without markings(no I/C markings despite the steel cylinder). I also asked which number in the Type code denotes the color, since I looked up another orange one, and only one number matched. :huh:
I'll see when they get back to me.
BigWes
Alabama
Well, the link I sent you shows an engine with a like type valve train setup with the large one on the exhaust and a more normal one on the intake side... So... I'm assuming that thing came built that way. Let us know what Briggs tells you.
JTSpeedDemon
Texas
The 4 HP one you linked has two identical retainers, but the parts diagram for mine shows that the same model engine(mine) was built with three separate exhaust valve spring retaining systems over the model's run.
If you look at the diagram here:https://outdoorpowerdirect.com/page...on,_Oil_Fill,CrnkCse/132432022701/8510002AT/y
You can see that the parts diagram does indeed show the beefy retainer on the exhaust valve, so yes, it's factory.
That same diagram also lists the intake valve spring as "SPRING, Valve | (Exhaust)", so I think it has heavier valve springs from the factory essentially. It would make sense that the thicker one is heavier, it certainly feels noticeably heavier, and if it has the normal exhaust valve spring on the intake, that would essentially mean heavier valve springs, and higher potential RPM.
I want to get a tach on this thing with the Raptor rod in and the gov removed. I wanna know where it'll valve float with this setup.
I'm waiting for Randy H and wenee9w to chime in as well, they'll probably know(along with sid:p).
Dang! This engine is so unique! Just about everything is different from the run of the mill plain bearing, kool bore, pulsa jet flathead!
Oh yeah, PS - The 555207 standard Raptor rod is out for delivery today!!:wai: I may have a running, upgraded engine by the end of the week!
Randy H
Tach is a good idea.
There's a lot to know about valve springs. Coil bind isn't likely to be an issue with a stock set up.
IDK, with your carburetor and cylinder head, you may not get to valve float. Flow is a big issue with flatheads. With regular heads guys stack gaskets, sacrificing compression to get better flow.
JTSpeedDemon
Texas
Thanks for the input.
Do you know anything about the "13 S" stamping or the strange valve spring/retainer setup(see post #7)?
Randy H
Found this on one of the Facebook sites. Guy said it was from a dual bearing block.
Searching for more info.
JTSpeedDemon
Texas
Hmm, might be a stamping for dual bearing blocks.
That still leaves the exhaust valve spring system in question.
