..I'm running an authentic comet 30 with aluminium weights and white springs. ..running 55mph at 3800 rpms...
he said
?! HOW..
with aluminium weights (148g) and white springs you raised engagement speed to 4000 rpm ..
which means @ 3800 rpm the clutch isn't even fully engaged yet
(and most power is turned to belt dust and heat)
and since the clutch isn't even fully engaged @3800
the overall ratio would be 10.2:1 soo you're travelling at maybe 20 mph
Sorry Matt, but something you said is clearly wrong..
I hope spring color and or flyweights..
said I...
...Aluminium weights, blue springs and the green spring on the #3 hole on the comet driven put me at 55 mph on flat land. I'm 270 lbs. I've ran a 60, 54, 46 and 38t sprocket. The 38 has given the best results....
great, now the garters turned blue.. good.. we finally have a fully engaged clutch in your TC,
and even enough oomph to get it to shift up a notch
~1:03:1 is close to 1:1 but still far from the possible 0.9:1 the TC is capable of
(that'd result in the aforementioned 60++mph)
And there's little room for reasoning I'm afraid:
the engine doesn't have enough power (TORQUE!)
to make it shift up further at that specific rpms. period!
With an engine allegedly hoarding 20 horses,
that can only mean ONE thing:
your gear ratio is terrible for your engine and setup.
Either the engine has far less power than claimed,
or the engine has a significant lack of torque up to 4k rpms
and only starts pushing above that threshold (like a 110° cam or so)
in both cases you need to gear lower in order to cross that dip.
since a stage 5 engine is far from being limited to just 3800 rpms
(very likely capable of passing 7k rpms with ease)
there is 100% no reason to not make use of the additional rpms that are at your disposal.
And that raises another issue with the terrible gear ratio you have:
you CANNOT reach the theroetical max speed with it!
you simply cannot break the laws of physics,
therefor your top speed will be limited to roundabout 80 mph
(at whatever rpms your peak hp is set to be)
And that suggests a 5.5:1 or lower gear ratio
I doubt your engine has a governor (all modifications of a stage 5 engine are rendered useless with one)
Sure you're far from being skinny and ridning a far from being lightweight bike.
and that combination isn't working in your favour at all
BUT if 55mph is all your engine is capable of,
then it has less than 8hp! (7.4hp to be precise ...a very mild stage 1 engine that'd be)
So yeah.. pick the flaw yourself..
(hint: engine power or gear ratio are BS.. maybe a combination!)
PS funny btw that you show us a pic of a SR hemi Tillotson 212 (10hp)
and not bsp 196 stage 5 (20hp) you claimed to have installed.. just a coincidence I think
