GO kART WONT MOVE
EKOSMUS
I have a gx160 5.5 hp that i mounted on a 2 seater go cart made by carter. It will not move with 2 people on it. It will barely go up a small incline with my 50 lb son on it. The clutch is new. I wonder what I can do to get more torque out of it. It will go fast when it gets up to speed but only works on flat ground. The back tires are around 15 in. how do i get this to move?
napalmfire
This is one of the drawbacks to a standard clutch versus a torque converter. The clutch must slip until it is up to speed to where it can lock metal on metal for the most speed. I would suggest opening up the clutch and roughing up the inside of the drum a bit with some medium grit sand paper. You may be able to get the clutch shoes to lock a lot easier if you give them something to grip. If it does slip a lot though, you may experience a rather hot drum. Do you see any signs of the clutch bell burning? Does it smoke a great amount?
You say it is new, sometimes they also do take a while to break in. Giving em a scratch speeds this up a bit.
EKOSMUS
When i say new i mean it has been run about 10 times. I will try roughing it up. it will not even pull up the slight incline on the drive way. It did smoke a little
napalmfire
My friend had a new one and at first it had trouble up the driveway. now he can do it with no problem after about 3 hours of time on the clutch. How much time does the clutch have on it? how much do you estimate it slipping and engaged?
Rough it up a bit and see how it fares.
If you cant get it sorted out, a larger axle gear and/or smaller clutch gear should help.
Here's a link to a gear ratio chart : http://www.diygokarts.com/speed-calculator.html
(If you were to gear it to only top out at around 20 mph or so, it should climb much better)
There not cheap but you also might consider switching over to a Comet torque converter system like this: http://www.google.com/search?hl=en&...lt&cd=1&q=comet+Tav2+torque+converter&spell=1
(I've seen new ones selling on ebay for much less than full retail)
You'll find serveral DIY threads discussing the advantages of torque converters in this search link: http://www.diygokarts.com/vb/search.php?searchid=75584
EKOSMUS
i will let you know all of that tomorrow. i am going to look when i get home. what all do i need to look at to give you all the info you need
TOO FAST
Canada
Sprocket size is a good place to start like K says but I'd like to
know if it was like this before the new clutch, has the cart always
had this problem or is this something new. Is the engine bogging
down or the clutch slipping excessively
EKOSMUS
This is the only clutch that has been on the cart. It does sound like it is bogging down. the cart does move easily when i push it. I thing the engine may be bogging down now that you said that. What do i need to look at on the engine
Kaptain Krunch
Pro Junk Collector
vermont
Your chain is probably too tight if its hard to push by hand, how tight is the chain?
Sorry i read that wrong, thought you said it doesnt not move easily. probably not the chain then.
EKOSMUS
the chain does not seem that tight but that would make sense. i will check that when i get home
TOO FAST
Canada
Might be a good idea to make sure the engine is 100%. Check
or replace spark plug, clean air filter, try new gas, change oil,
make sure throttle is opening all the way... It kinda sounds like
an engine problem, the kart wouldn't have operated this when
it was new would it? That means something has changed
TOO FAST
Canada
Tell us how many teeth on the clutch and how many teeth on
any sprockets after that - a picture would be good too
mike75925
thinker and tinkerer
Alto, tx
though not a very common problem, the float could have a hole in it. or the float is not to spec (since they aren't adjustable). or maybe just alil trash in the circiut.
While looking into all those other things, also make sure your brakes aren't sticky or dragging. Might seem like a no-brainer, but it could happen!
EKOSMUS
Ok i did not count the teeth on the sprocket but the clutch has 10. It is a size 41 chain. Also the clutch is getting real hot and smoking. i cleaned the carb and check the chain. It has started backfiring and almost dies when you let off the gas.
EKOSMUS
What about the clutch smoking. also if i raise the back wheels when it is idling it spins
