IMO live axles SUCK
…on heavy karts
...or with big wheels
…& especially on paved surfaces
Differentials can solve this problem
...but, they have their draw backs too (extra weight, additional losses, added cost etc.)
I've seen folks who have removed (1) of the keys, that lock the wheel to the axle (so, it freewheels)
...but, since there is no bearing between the rim & axle it, there is usually a huge wear factor
...which eventually destroys the rim &/or axle
I've seen variations of modifying a live axle so it allows (1) wheel to "slip" a bit, when necessary
Remove the key out of (1) rear wheel
...but, instead of just letting it "freewheel", add a spring (around the axle) between a keyed hub (sprocket, brake etc.) & the keyless wheel
This would/should apply rotational force to the keyless wheel 99% of the time
...but, would/should be able to "slip" when the wheels are rotating at different speeds (like in turns)
* The amount of pressure should be easily adjusted
...just by tightening or loosening the wheel nut.
** Maybe could even add a "friction disc" (brake/clutch like material) between the spring & hub
…& also maybe another between spring & rim (for additional "grip &/or even to reduce wear)
*** If the wheel & axle rotate at the same speed 99% of the time
...the rim to axle wear should be kept to a minimum
…on heavy karts
