idk how to setup a torque converter
YeaProbably
i tinker...
Georgia
I have the same engine as coleman ct200u in a gokart its a honda clone/ off brand predator 79cc but it has 98cc.https://www.walmart.com/ip/Coleman-Powersports-100cc-Gas-Powered-Go-kart-Black-and-Red/480257966?wmlspartner=wlpa&selectedSellerId=0&adid=22222222227102818906&wl0=&wl1=g&wl2=c&wl3=217668019152&wl4=aud-566049426705:pla-353066965138&wl5=9010842&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=online&wl12=480257966&veh=sem&gclid=Cj0KCQjwvdXpBRCoARIsAMJSKqKt8vaiwqyJ7ZHcBesjkSUJR-snm2O7V3PQHI-8x7QSVdwmFysoVd0aAhQxEALw_wcBi was planning on putting this torque converter on it https://www.amazon.com/Torque-Converter-Clutch-System-Replacement/dp/B07H7J2B14/ref=asc_df_B07H7J2B14/?tag=hyprod-20&linkCode=df0&hvadid=316708741155&hvpos=1o2&hvnetw=g&hvrand=13144903977190003142&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9010842&hvtargid=pla-591905416315&psc=1 but i have no idea how i would do it. there a picture of the clutch and the current gear setup VVVVV(dont message about how bad the clutch is ik)
a few questions:
1.where do i put the clutch with the torque converter?
2.what do i do with my other gears?
3.how do i attach the torque converter to my other gears?(i can move my engine if needed)
4.does the torque converter replace the clutch?
Zombient68
That's not a torque converter, fam. That looks like a setup that's trying to gear it down.
Your kart doesn't need a TC, could use a new 212...
I would probably agree with Mkutzy here. Once you have a larger engine, you will probably not need a TC and you could just use the gearing that you have.
If you do want a TC, there are many examples of them on the website. I would snoop around a few threads and check them out.
Comet identification, installation and belts. Sprocket and spring changes. Have a look at these links to see what you are getting
http://www.gokartsupply.com/identify.htm
http://www.gokartsupply.com/tcbelts.htm
http://www.bmikarts.com/PDF/Comet_40series.pdf
We can always help you get going if you want one. You will not need the centrifugal clutch that you have on your kart now if you get a TC.
YeaProbably
i tinker...
Georgia
ok i was thinking about getting a 212
---------- Post added at 07:13 PM ---------- Previous post was at 06:55 PM ----------
i know its not a torque converter i was talking about getting one lol
mrdeadman1
Lawrence area, Kansas
ok well if you get a 30 series tav it just bolts on, no guess work it's pretty straight forward.
---------- Post added at 08:24 PM ---------- Previous post was at 08:22 PM ----------
also that 3 hp engine isnt going to do it. it would be the same as the ct100 not the 200 it uses a 196 cc engine
