OK, I've got a
66 tooth sprocket, so it may be aftermarket, or there were simply variations by Bird/Phoenix Engineering, which there obviously was since your seat has stripes and whatnot while mine is flat black.
Maybe mine was the base model.
As for "ratty" tires, they are tube type, so theoretically you could run the tires beyond bald as long as the tubes are good.
My fronts have some pretty sizeable cracks in them, but the tubes still hold air nice!
The nice thing is that all the wheels are 4.10/3.50x5 tube type on a split rim, so they're a common size, last a long time, and they are easier to change.
---------- Post added at 08:16 AM ---------- Previous post was at 08:14 AM ----------
Yup, after looking at the pictures, the whole pedal needs to be moved down one hole. Same thing for the brake rod clevis.
