Think about it some more, I'm sure you will see why changing the wheel circumference doesn't change the generator speed at all, or a VERY small amount.
(Unless you are talking about a smaller friction drive wheel on the actual generator, then you are correct)
I disagree - 1 rpm is 1 rpm so if the wheel is 10 inch diameter
the circ is about 31 inches. If you change to a 20 inche the circ
is about 63 inches. That means the generator wheel turns twice
as far in the same revolution = faster gen speed.
If you mean the same road speed then you are right because the
small wheel would travel twice as many rpm as the large one and
the gen wheel speed would be the same
