Stage 2 420cc, what size Mikuni?
I will soon be building a stage 2 420cc with the kit from GoPower Sports but I would like a Mikuni carb. What size should I go with, I see GPS has them up to 26mm but from the forums I keep reading people using 34mm kits.
Any recommendations?
--Dan
Mammoth
Durham, CA
People often undersize there carb and don't even know it. If I were to build one for max hp I would put two 36mm carbs on it.
Go with a 40mm Dellorto. They flow better than most carbs which equals hp.
Ebay sometimes has good prices on them. New they're around $200
Thanks for the info... I am super new to all this so lots of questions coming. I will probably stick with one carb just get one that is big enough just for compactness.
My biggest concern is the flange to adapt a different carb to either the Mikuni or other carb. Are these widely available?
--Dan
Joe-405
Enjoying New Projects
U.S.A.
I had a 34mm on my 420cc and it was perfect. Had cam, long rod, higher compression, and open exhaust. I wouldn’t run bigger than that unless you have extensive head work done.
I like that adapter with the pulse fitting on there makes it easy to hook up a pulse pump.
I also assume that with this adapter I would need a rubber boot (or whatever it is called) to hook up a 32mm Mikuni or is it possible to hook up a 34mm here with the correct boot?
Thanks for the help so far.
--Dan
Joe-405
U.S.A.
I had that exact adapter and a piece of hose with a 34mm on mine.
It was my last years buildoff dragbike thread.
The KOSO carburetor I had worked great but it pushed through the needle and seat with the fuel pump at idle or off throttle. It was a dribble but it for sure leaked out the overflow.
Awesome, love to see this! Where did you get that rubber boot/hose/whatever connect the adapter to the carb. Was it just a 34mm inside diameter thing with some hose clamps? Something I can pick up at like Home Depot/Lowes type of deal?
--Dan
Mammoth
Durham, CA
You can gain more hp by making the intake a proper length.
On a 420cc engine thats going to run at about 6500 rpm the intake has to be 13.5" inches long.
The measurement is taken from the valve to the end of the carb.
That makes the intake tube 6" inches long.
Intake tubes are simple to make. They don't have to be pretty, they just have to be smooth on the inside.
Trace the gasket onto a piece of 1/4" inch thick steel and cut it out.
Then make a tapered tube that fits both ends, carb and cylinder head.
Next just weld them together
The rubber boot is just radiator hose.
Here's what I run. 40mm Dellorto with a 6" tube, and it works fantastic. This setup goes right through the rpm with instant response. Ive been very pleased with how well it runs.
Excellent info so far, like I suspected I have a lot to learn from all this. I may make it a bent pipe with a constant radius just to fit, once I have the frame in my hands I will def know more about how to set it all up.
Thanks for all the info so far, if anyone has any other wisdom to share I am all ears!
--Dan
Mammoth
Durham, CA
Any bend in the ports will slow the air flow down and you will lose some hp.
Porting is not only about making the ports the proper size in relation to the other parts, its also about making them as straight as possible.
Here is a cutaway of a Hybusa. They have the intake so straight its almost touching the parts of the valve. Thats how hp is made. Get it to breathe.
The exhaust port is not as critical as the intake port. Once you get about two inches past the valve you can begin a bend without effecting hp much.
Joe-405
U.S.A.
My 420 ran 7500 with the short intake sir. And that was actual numbers via tachometer.
It ran consistent at 6240 with the stock flywheel. And went up with the new timing and billet flywheel.
Mammoth
Durham, CA
The intake is tuned to work when the engine is producing its peak hp. These engines make there highest hp around 6500 rpm.
To calculate how long the intake tube should be just take 88000 and divide it by the rpm where you want the hp to be at.
On this engine we want it at 6500 so that equals 13.5. Which is the total length in inches from the valve to the end of the carb.
This works just like a tuned exhaust. When the piston goes down it creates airflow in the intake, and then the valve slams shut causing the flowing air to bunch up and pressurize.
The length of the intake controls when the max pressure happens, and you want this to happen right when the intake valve opens up again so the pressure forces the air into the cylinder just like a supercharger.
You can get 10% more hp by doing this. So its no small deal.
It would be an easy test to do. Make an intake just like the one in the picture and see if there is any difference in performance.
To calculate the size of the carb needed just take the displacement of the engine and divide it by the area of the carb in square mm.
The number to aim for is .200 on most engines.
Just for example if the number is .300 the carb is too small, and if it is .100 the carb is too big.
The area of a carb on a 34mm is 907.9. The equation works like this. 420 divided by 907.9 equals .462. Which means the carb is too small.
I recommended the 40mm Dellorto because larger good quality carbs start getting real expensive.
The 40mm carb is still undersized for this engine, but it will work quite well.
Anybody who has run a Dellorto on a dyno always says the same thing. "Yeah we get 1 to 2 more hp with those."
Just for reference here is the area of carbs in square mm for anybody wanting to calculate there carb size to there engine.
Remember your shooting for .200 on most engines. Fuel injection throttle bodies can be even bigger. I have some data where one engine has a number down to .110
Carb. Area in square mm.
22mm 380
24mm 452
26mm 530.9
29mm 660.5
30mm 706.8
32mm 804.2
33mm 855.3
34mm 907.9
35mm 962
36mm 1017
37mm 1075
38mm 1134
39mm 1194.5
40mm 1256.6
42mm 1385
43mm 1452.2
44mm 1520.5
48mm 1809.5
50mm 1963
60mm 2827
