J.S.@SMS
Road Hazard
I am in the planning stage of a kart that I will be building over the summer and I am not sure what clutch to use. It's a carter 2575 that I will be trying to keep under 150-200 pounds. It will have a stage two predator 212 with an upgraded intake, 22mm mikuni carburetor and an open header. I'm hoping for about 20-25hp. I will also be using 11 inch tires on racing wheels.
The clutch that I would like to use is the bully 3 disk 6 spring clutch which is rated for 30hp.
https://www.gopowersports.com/bully-3-disc-6-spring/
My question is, Is it possible to gear this setup for 60+ mph or would that put too much strain on the clutch.
PS: I do not plan on driving the kart at 60 miles per hour, but I would like the extra speed for drifting. And this kart will likely be used off road for drifting in an open field that's flat, mostly level and covered in grass as well as on road.
