don't mind me, jutst putting the foot in the door
Are your wheel offsets the same on either side? I've got some metric 5"x5" (fronts) sitting around if you end up needing any.
I think it's kind of cool that your seat is offset for oval, to counter your battery weight.
That's a trick question...wider rear track is a bit counterintuitive because it will help you rotate. That's really why the rear hubs are so adjustable. Each track will have it's own "best" setup.
Thinking about it some more, that heavy motor hanging off the back is going to make the rear work harder than usual so you may want to stay wide, to loosen things up a bit more.
Let a bunch of friends ride it off and on over 2 days with all stop starts and donuts etc. Biggest guy being close to 300lbs. And recharging the batteries she took 9ah. and the voltage of the packs was down to 15.84volts from 16.8.
Anyone have a link to a cheap volt and amp gauge that can handle 400amps?
