Project Rocket Kart #4
rushking19
Richmond Virginia
I'm back again finally I've been busy but I finally got the go kart running again, still needs a few thing like new spark plugs so it can run better I ordered new spark plugs already, but its running nun of the less need to scoot the motor a little bit more so everything can line up and then can put the clutch back on and I also need to order the adapter shaft and then the drivetrain will be complete, then I can technically drive it but the exhaust still needs to be made
Atlanta, GA
Great work so far. I'll be curious to see how that clutch works under load. The exhaust is going to be a challenge too.
rushking19
Richmond Virginia
Hopefully it works well under load so far its working pretty good and is in sync with the primary so we'll see how that goes once I connect the chain and the exhaust will be pretty hard but I'm planning something
I'm actually planning on using 2 of these pipes and then make a y pipe that will connect the 2 and ten ho under the axle and have a rlv muffler on the end
J.S.@SMS
Road Hazard
Weeki Wachee Fl.
If you want my advice, don't run the two exhaust pipes into a single tailpipe and muffler. My suggestion is to run a true dual exhaust and two rlv mufflers. Not only will a dual exhaust look cooler (in my opinion) but it will provide more airflow, which yields a slight bit more power. However this is your kart, so go with the design that you want to go with.
anickode
S.E. Michigan
A PROPERLY designed 2 into 1 would yield a slightly better gain than separate pipes.
And it's a two stroke, so it's even more important.
A tuned resonant pipe would be best.
rushking19
Richmond Virginia
This engine never came with a expansion chamber when it came out it was before that so the pipe I plan on running shouldn't effect it and also the two pipes together would sound better than one in my opinion but nun of the less ot should sound interesting
This is the rlv muffler I plan on using to quite it down and how I want the exhaust tip to be, and the space I have to deal with the seat rail is actually getting removed so I can have more space to work with and also so the seat can sit lower, for a lower center of gravity
S S
idiot who has little clue
now all it needs is an actual rocket on it.
anickode
S.E. Michigan
A 2 into 1 will also improve exhaust scavenging if it's designed right, and your muffler isn't too restrictive.
anickode
S.E. Michigan
That's what I was thinking and it shouldn't be restrictive rlv is a high flow muffler
Just because it's "high flow" for a lawnmower engine doesn't mean it's "high flow" for anything else.
That's what, a 440?
Double the displacement, 2 stroke instead of 4, spins twice as fast... You are probably looking at anywhere from 4 to 8 times the total volume of exhaust produced by a 6.5 hp 4 stroke.
I could put a 3" flowmaster on my little pickup truck and it would be "high flow". Put that same muffler on a semi truck, and it would be a massive restriction.
Granted, a 2 stroke likes a LITTLE restriction, especially without a tuned expansion chamber, but you really need to make sure that it's not too much.
Horsepower is a good, albeit basic starting point to gauge by. Would you run that same muffler on a 2 into 1 header on a 670?
I'm not saying it won't work, just that it's a little more complicated than saying "high flow" on the box
rushking19
Richmond Virginia
That's what, a 440?
It's a rotax 399 and it should be fine or else it's the first thing I'm changing it's a straight through muffler with baffles so it should be fine and pluses I'm enlarging the entry of the muffler anyway
rushking19
Richmond Virginia
After hours of filing they are finally slotted and the chain and belt line up perfectly
rushking19
Richmond Virginia
The new park plugs finally came
