sf_karting
Hey guys. Previously, I made a post where I tried to get help on identifying my go kart frame. I found out it is a MxK Racing Demon II from the mid 1990's. In that thread, I also was asked questions about the predator 212 that came with it that has the governor removed. The whole governor unit was removed and the hole was plugged with a screw. Now that the engine can rev much higher, what should I do to prevent the valves from either going through the piston or to prevent them from mushrooming? As of now, I'm thinking of replacing the valves and pushrods with stronger billet parts, and I'm most likely going to buy heavier valve springs. Any other recommendations as what I could and/or should do to prevent a potentially bad end for a good, nearly brand new engine?
