Harbor Freight wheels...
cheapskatekarting
I bought a go kart last summer as a project. I got it up and running and everything an ran it around a good little bit. I came back to it this year to find that one of the tires had gone flat. When I bought it, only one tire was bad. I had replaced it with a typical, higher quality one. But when this one went flat, I wanted to see if I could get a better price. So I hopped on the Internet and one of the first options to show up was Harbor Freight. Lol. I know. The good 'ol dollar store of all things hardware. But they had a wheel that was the right size, and I could get it dirt cheap. I figured that if it didn't work, it was no loss as the thing only cost $4 with a coupon. So I bought one, brought it home and put it up against the tires already there. I noticed they were incredibly similar. In fact, it turned out that the previous owner had actually put this very same tire on this kart (minus the rims; the kart came with some really nice aluminum ones). And they had held up against the wear I had put on them all last summer. So now I am somewhat of a fan of these wheels (I still prefer higher quality driving wheels because they agree better with a live axle; as for steering, though, I'm all for them!). Now I am looking to modify the rims to be more usable, because as they are, I wouldn't dare. They are made of thin, cheap metal and have awful bearings. Any suggestions as to how I might be able to make these rims worthwhile?
Texan
Senor Member
Deep In The Heart of Texas
There was a thread on here by member named Poboy awhile back modifying them. Don't remember the results tho. What size are the tires? Got any pics of the kart?
cheapskatekarting
The tires according to the Harbor Freight website are 10" wheels by Haulmaster. Size I believe is 4.10-3.5/? just off the top of my head.
anickode
S.E. Michigan
The hubs are just pressed together, not welded. They will break apart eventually, sometimes within minutes depending on terrain and driving style.
You could weld the hubs together, put some 1⅜" go kart bearings in them, and they'd hold up for a bit, but still not terribly long.
The tubes never hold air for more than a day or two (at best) and the foam/vinyl/God knows what tires will scrub bald in no time.
But if you have a set and you're stuck with them, a few tack welds connecting the hub tube to the hub flange, plus some go kart bearings will at least make them not fall apart as fast.
