Help please. Clutch removal, and finding a new one.
Toretto7
Texas
Ok, so I’ve finally given up on searching and searching for the answers to removing this clutch. I decided I’ll finally just create a thread and ask for myself. I have an old 10T, #40, and I’m assuming 3/4 until I can get it off to measure. It’s to a Briggs and Stratton and as far as I know it’s the original that was placed on there 20 years ago it so. It’s a one wheel peel ThunderKart.
I hope that worked, I haven’t used forums in a long time. And yes, that is oil and grease all over it and I don’t need the talk. It was shot long before all that somehow got there.
anickode
S.E. Michigan
Loosen the set screws and pull it off. If it's seized on, a small 3 jaw puller will probably get it off of there.
Another option is to remove the snap ring/Jesus clip and slide the drum off, then remove the springs and shoes. The guts might go kablooey when you pull the drum off, but they shouldn't. Then all you have to contend with is the inner carrier and sleeve. This opens up some options as far as heating it.
Toretto7
Texas
Ok, thank you for that info. But does the set screw in the third picture need to come all the way out? It will wiggle when I turn but doesn't want to turn much either way. I sprayed it down with penetrating spray and still wouldn't come out any further. In the fourth picture it doesn't seem to have anything.
Edit: Do I need to do something to the outside facing tip of the clutch to have it come off?
(just making double checking to reduce the risk of me utterly destroying everything.)
anickode
S.E. Michigan
The way it's on there, you should just need to back the set screws off. Taking them fully out could help if it's rusted on, by giving a good path for penetrating oil to get in there.
Besides that, there is nothing else holding it on. What you see on the end of it is the end of the crankshaft, so you can measure that bit and order a clutch before you get the rest off.
Toretto7
Texas
Sounds simple enough... I’ll try and get back to it when I can. The set screw doesn’t want to come out. It would just turn a small bit and not turn no matter how much force I applied. Do I measure the width of the crankshaft to order a new one?
Tpdingo
Bellmore, NY
1: I had some set screws and allen heads that wouldn't come out. You can take teh box end of a wrench and hook it on to the allen key to extend the leverage you have.
2: Yes. The 3 common sizes are 5/8"(2-3hp motors),3/4"(5-6hp motors), and 1" (8hp+)
Toretto7
Texas
What kind of clutch do I need in order to replace it? Most clutch for sale have the bolt on the end of it. Would it be fine to replace it with that? If so, what kind of bolt/washer would I need?
Tpdingo
Bellmore, NY
Get a normal bolt one. You can go to any go kart distributor to get one. They range from 20-300$, but 50$ is good for a high quality yard kart clutch. $100+ is for racing only.
The bolt should be 5/16 x 24 if it was made in the last 20 years. Note, THIS IS A FINE THREAD BOLT.
