V-4 Two Stroke 1025cc 275HP @ 10k RPM
http://www.aaenperformance.com/v4_racing_engine.asp
V-4 Racing Engine
The unique V-4 engine design combines light weight with the strength to take the punishment of the most demanding conditions. The durability of the design has been proven in SCCA road racing where the V-4 engine has raced problem free for several seasons in our D-Sport race car.
1000 cc engines are presently also used in snowmobile ice drag racing and ATV sand drag racing.
The compact low inertia crank fires every 90° and allows us to rev the engine in excess of 12,000 RPM without running into any critical torsional vibrations. The 1000 cc and 800 cc drag racing motors have been raced for 7 seasons without any crank or clutch failures.
V4 Racing Engine
10 Port Cylinder Design
The 10 port cylinders have been carefully developed to deliver maximum cylinder filling efficiency. The cylinder filling is taken care of by 2 piston controlled intake ports, five transfer passages and triple exhaust ports. The back transfer port is a unique design that runs inside the intake port divider, giving it the direction it needs for efficient scavenging, and at the same time allowing for maximum intake flow area. A special forged piston with a wide intake skirt insures that the intake port is large enough for the highest engine speeds.
Cylinder cooling includes a water jacket around the exhaust port. Sealing between the cylinder and head is taken care of by double O-rings.
The V-4 engine breaths through a special 4 barrel manifold with 52 mm intake diameters and electronic fuel injection.
The V-4 racing engines are designed specifically for racing.
We will only sell these engines to qualified Race Teams with solid budgets large enough to support extensive development necessary for top level racing, for more information on the V-4 Engine, please refer to the SAE papers #983071 and #983080 presented at the 1998 Motorsports Conference in Detroit.
Joe-405,
I'm looking forward to next year's build off. LOL
How about a SmartCar?
Geod919
Part throttle tuning will probably be difficult. Lol. What price point are these at?
If you have to ask....
I have no idea... I might need a sponsor if I want one.
"We will only sell these engines to qualified Race Teams with solid budgets large enough to support extensive development necessary for top level racing."
Kansaskart
Yeah I could see someone here putting a $12,000.00 engine on a vintage Sears fun kart. Lmao!
Per the website:
"We will only sell these engines to qualified Race Teams with solid budgets large enough to support extensive development necessary for top level racing, for more information on the V-4 Engine, please refer to the SAE papers #983071 and #983080 presented at the 1998 Motorsports Conference in Detroit"
I'd like to find one of those dual jet engine karts made in the 60's that had engines that looked like a basketball and pit these two against each other. The dual setup was good for around 200mph, airborne karts and dead bodies. True story.
---------- Post added at 05:15 PM ---------- Previous post was at 05:06 PM ----------
And here it is:
I read 1 was good for 150mph. 2 were 180mph+.
https://barnfinds.com/rocket-thrust-go-kart-barn-find/
---------- Post added at 05:27 PM ---------- Previous post was at 05:15 PM ----------
Check out these video selections. Hilarious! I still remember my twin Mac 101 kart. It would down right scare you can't imagine the new stuff.
https://www.google.com/search?q=tur...ndroid-att-us&sourceid=chrome-mobile&ie=UTF-8
---------- Post added at 05:28 PM ---------- Previous post was at 05:27 PM ----------
I like the jack McClure vid.
anickode
S.E. Michigan
I know a guy who used to run a turbonique rocket turbine drag bike.
The system was basically a cross between a rocket engine and a turboshaft engine. The rocket exhaust spun a turbine that produced massive amounts of power for a short time. Combined with a bit of pure rocket thrust.
They also had the rocket drag axle, which was a solid rear end with a rocket turbine built into the pumpkin, inputting torque via a second pinion gear from the back.
So basically unobtainium to the average person. Probably a $30,000 engine. Rather take a fan/oil cooled sled engine and build it up, and still be less than a quarter the cost.
