need help please help me out.
mykol93
Carlise pa
ok so my briggs 5 hp MOD#135212 was running great all of a sudden the thing started staying at full throttle disconected the throttle linkage ran it same thing stick wide open and wont return to idle unless shut off. it will start n idle but when you open throttle a lil it goes wide open and sticks there. please give some ideas.
motor_head
expert garbage picker
sutherland IA
weights might have broke off never heard of that happening you should open up case and take all the gov parts off
mike75925
thinker and tinkerer
Alto, tx
is the throttle cable adjusted properly? take the cable loose at its clamp, hold the sheath while actuating the throttle pedal. if you get full actuation, retighten. if not opening all the way, pull the cable. if too much push the cable. this is a flat head?
mykol93
Carlise pa
update
ok so i tore motor out of cart started tearing it apart. i need a clutch puller. my ? is while i have the clutch apart is there any thing i can do to make it engage a lil smoother? it is 2 metal shoes. now it is jumpy when we go to take off. any 1 got some ideas?
EagleTalons
Master JB Welder
Forsyth, Montana
If it has Overhead Valves wrote on it, or is the head comes off to the side, it is a OHV engine. If it comes straight up with the sparkplug on top and a "flat" head. It is a Flathead.
A pulse carb uses the engines natural suction to pull the gas into a bowl below the carb. A non pulse carb can only suck a small ways and needs gravity or a fuel pump to receive fuel.
mykol93
Carlise pa
witch one is better? i have both i think a briggs 5 hp is pulse. and a honda 6.5 gx 200 not sure if its pulse. i need to rplace carb on honda so trying to determine waht i need.
