Gokart calculations....!!
Kmukum
India
HI
I am participating in a go-kart championship. I don't know the which are the important parameters to calculate in steering and braking system and I have no idea. So Please help me with the calculations involved in the steering and braking systems.
Thank you
josh7owens
Lol what?!
This post seems like it’s from a 5th grader.
To answer the question though. If the brakes can lock the wheels, then the braking is limited by the available traction the tires can achieve.
Steering... weird question. I suppose turning radius, caster, camber gain/loss relative to caster. Assuming the kart has a fixed suspension you don’t have to worry aboutbump steer or how that affects camber, toe, or caster.
Kmukum
India
Lol what?!
hi josh7owens,
yeah i totally understand what you think but i am new to fabrication of gokart. so don't criticize anybody without knowing their issues. I totally respect you for replying with the your suggestion.
Thank you
65ShelbyClone
SoCal
We need more information before we can make specific recommendations.
1.) What are the categories of competition?
2.) What are the kart design requirements/rules?
If there is an online rule book that we could look at (preferably in English), that would better help us help you.
Kmukum
India
Hi,
This is the link of the rule book.
https://bfkct.in/rule-book/
---------- Post added at 11:03 AM ---------- Previous post was at 10:56 AM ----------
And i'm using honda stunner 125cc with 5 speed gear box. I did some research and gone through some research papers for the calculations. I will also send my calculations.
This is the link to download my calculations
https://drive.google.com/open?id=1Q-gXfzW7h0HAepx2HN6bQehCMAh83iVA
:confused:
Are those formula correct?
I'm not 100% sure but I applaud your effort. I'm impressed with the report, even if I don't know if it is correct or not. I also try to apply laws of math and physics to karting, but this is neat.:thumbsup:
you missed a very very important part with the braking calculations!
the tyre width and therefore tyre patch that is in contact with the road;
tyre/road friction if threshold for sliding friction is met or not (which unfortunately is a fuzzy line :()
since without static ( or in this case rather rolling friction) the stopping power will be diminished
by a fairly large amount.
Surely depends on exact tyre material (assuming slicks.. otherwise + tread pattern)
but a good estimation can be taken from the tyre's rockwell hardness
that's why different tyres on the same car have different stopping distances..
same is true for acceleration break traction and all power is heat ;)
moving on to engine calculations.
kart speed or say top speed is mostly limited NOT by engine rpm but by air resistance since it is the fastest growing number in the resistance formula (being cubed)
so 10m/s end up as a factor of 1000, 11m/s yield a factor of 1331..
your 91 km/h (25.2778 m/s) end up as a factor of 16151.6844
so wind resistance coefficient times front facing area must not exceed 1.19 or else you motorpower is no longer sufficient to reach the estimated 91 km/h
that's actually quite good estimating a frontal area of less than 1m² you'll be fine even without fairing
You still want to be sure though.
tyres.. in general are smaller than their nominated diameter
(they flatten on the underside ;))
so hop in a kart with the intended tyres mounted (properly inflated)
and measure the distance between the axle center and the floor.
that's your tyre radius for good calculations!
haven't gone through every calculation didn't even check consistency really..
I noticed two things however..
you pull numbers out of thin air every once in a while
like the 746 [watts per hp] and worst the 11hp @8000 rpm
which is bad in papers like these..
be precise! it's rounded 745.7 Watts per bhp (.69987)
and where you got the 11horses from @ 8k rpm I have no idea (not having any engine documentation handy and being too lazy to search for some)
but it's rather safe to assume if the engine peaks at 11 bhp @ 9500rpm, the output power @8000 rpm will be slightly less than that.
But yeah.. nice effort put into that indeed.
add proper documentation and referncing and it'd almost pass as scientific :D
