Missing key from brake hub
Cibarius707
Heyoooo
Yerf dog owner here. Just picked it up from a yard sale for $150 working! Working a few kinks out and I hit the fence because the key/set screw for the brake hub is messed up.
The key is missing.. and there’s also a 1/2” bolt in the hub collar. The 1/2” bolt isn’t strong enough alone to hold for braking so I’m wondering if anyone can help me determine how those keys work and how to properly size a replacement.
Thanks!
Heyoooo
Thanks!
The first pic Illustrates how you could measure the depth & width of the key-size you need. (the key you need might be a metric or Inch size, so you need to very accurately measure...)
The second pic Illustrates how a correctly-sized key would perfectly fit in-between your axle and brake hub.
_________
Most Keys are perfectly square down their length, but not all, so measure carefully...
Most Ace Hardware stores have a few different sizes of Keys in stock. They call them Key Stock, they come in longer lengths then you might need. If so, you could use a Hacksaw cut/shorten it down.
You'd typically use a Caliper tool like this to take accurate measurements for the key-size you need: You can find some of these Caliper measuring tools priced as low as $5-$10...
Cibarius707
Thanks! Picked up some 1/4” from my hardware store and cut a chunk that fit in there. Seems to be holding. The set screw on the brake hub is tripped so I’m getting a new brake hub in the mail.
Thanks!
Joe-405
Enjoying New Projects
U.S.A.
I kept throwing the key on my Drag Minibike from last year buildoff. I finally just bought a long key and installed it where the whole length of the slot was all key so it couldn’t come out no matter what it did. Even if it was loose.
