Tecumseh troubleshooting
Cibarius707
Hey! Just picked up a yerf with 6hp h660-71131c
It’s cold blooded but won’t run after 5 minutes. Seems to be just crap out, sputter a little bit and then it is extremely hard if at all possible to restart.
Wondering if anyone has troubleshooting tips?
I was thinking piston rings maybe but want to check for maybe an easier fix before cracking the thing open.
Will run compression test this weekend if possible
Thanks!
Clogged fuel filter or line? Stuck float in the carb bowl? Stuck float needle?
When it dies, open the carb bowl or bowl drain and see if there is gas in there.
Sounds like the carb bowl might be running out of gas and not refilling.
Cibarius707
Thanks for both responses guys.
I’ll check it out first thing and keep you posted.
Thanks for the help. I’m trying to get the kinks worked out for my kid’s summer break!
Cibarius707
OK well I took it for a test run and it is stalling again, fuel is in the bowl, but going to check the float next. Pushing the primer several times gets it running again… For a little while each time.
If there is fuel in the bowl when it cuts out, then I don't think the float is the problem.
Atlanta, GA
I have one of those Teckasheema engines. It is part of the ritual of ownership that the carb be removed and thoroughly cleaned on a regular basis.
Cibarius707
Quick update. Played around with it some more with a buddy and tighten the bolt. There was lots of fuel, anytime I tried to peek into the bowl before or after stalling. So thinking carburetors… I went with the old assumption that there might just be a slight blockage. Tapped on the carburetor with A hammer… And the issues seem to resolve it self for now. That is super cool, engine still hits pretty hard even when battling the stall… I don’t think it is piston rings. Thankfully
---------- Post added at 08:21 AM ---------- Previous post was at 07:34 AM ----------
Thank you. Even an entirely new carburetor is affordable, cleaning/replacement coming up.
Xtreme Yard Karts
Sweet Home Alabama!
If you keep having trouble, you can buy replacement carbs really cheap. They work really well for the money.
https://m.ebay.com/itm/CARBURETOR-C...505962?hash=item41c8e7c22a:g:h1AAAOSwWHBaTIE3
If you want to hop the engine up with an aftermarket air filter, header, etc., it's best to put a fully adjustable HS50 carb on it. The fuel inlet is a little different, but the will work and will allow you adjust the low and high side settings of the carb.
https://m.ebay.com/itm/Carburetor-C...485232&hash=item5b40a99adc:g:GS8AAOSw-wFZbfE4
Cibarius707
Lol definitely went the “**** it “route and ordered the new carburetor. Should be here soon
