Worst drivetrain setup?
Tpdingo
Bellmore, NY
Can anyone get worse than my drivetrain setup on my tinykart?
3hp predator
3:1 gear ratio
9" bald tires
40lb kart.
Hey, it moves....when it isnt throwing the chain to the moon.
Tpdingo
Bellmore, NY
Outer diameter. I can fill the tire to full in about 15 seconds with a cheap air pump. Kind of a statement and question.
anickode
S.E. Michigan
Sounds like a competition to me.
Belt centrifugal clutch to a 122" v belt that makes a double 90° bend and a 90° twist via idlers and tensioners, to a 9" jackshaft pulley. 12t on the jackshaft to 24t on a 3/4" axle. Hand truck split rims on homemade hubs that attach to the axle with a through-bolt like a snowblower
This I have to see!!!!!!
---------- Post added at 07:44 AM ---------- Previous post was at 07:44 AM ----------
3hp predator
3:1 gear ratio
9" bald tires
40lb kart.
Change the gearing up a bit. Get a slightly larger axle sprocket. Post some pics of what you have
Tpdingo
Bellmore, NY
Sure. The ratio is so slow because I have no ground clearence for it.
Atlanta, GA
Yeah we need a more "overall" picture, zoomed out. You might be able to cut away or relocate frame pieces to make room for a bigger sprocket.
