Set screw for gear?
Tpdingo
Bellmore, NY
I have a gear on the drive shaft that I dont remember exactly where I got it but it was an Amazon purchase with the following specs:
5/8" shaft
36 teeth
#35 chain
What would be the set sreew size for the gear?
anickode
S.E. Michigan
Set screw size is whatever they tapped it for. It SHOULD be 5/16", but that's kind of a crap shoot.
Set screws are cheap. Go to the hardware store and buy a few different sizes that look right. Whatever fits is what it is.
Or take the sprocket (not gear) in with you and find one that matches.
anickode
S.E. Michigan
Nevermind. Im a bozo and didnt see the set screw was in the hole 90 degrees from the empty one.
Should be 2. One over the keyway and one 90° from it.
Though on smaller shafts not always.
