Hammerhead twister engine replacement 33 cc
chemcounter
Missouri
I have a little two seat hammerhead twister cart with a four stroke 39 (corrected) cc engine. This kart is perfect for the younger kids because it is slow and mostly safe. Unfortunately the engine is toast. The drive is on the right side of the kart with a transfer case and clutch mounted to the engine. Are there any direct replacement engines I could install with the same setup or am I looking at a complete restructuring of the drive components? I noticed later models of this kart switched the setup to use a 130 cc engine with the drive on the left.
chemcounter
Missouri
It is a four stroke. It has a cdi like a gy6. Looks like a weed eater engine but most chainsaws and weed eaters are two stroke. I am not opposed to converting to two stroke or different size but I guess my assumption is that the manufacturer would use something somewhat universal that I can't seem to find.
---------- Post added at 11:40 AM ---------- Previous post was at 11:09 AM ----------
Pictures uploaded in my profile.
qtband
St. Louis, MO
That's a little motor. I looked at the pics, but do you have a pic of the whole kart? It helps with perspective. Maybe a Predator 212 on it?
chemcounter
Missouri
A predator would require a change of the drive side. This kart has a solid axle but cannot be swapped to the other side due to the brake and how the steel mounts are placed. Is there an aftermarket transfer case for a predator that would allow right side drive? Harbor freight has the smaller predator I could use if a transfer case that fits exists.
The model is um39ii so it is probably a 39 cc instaed of a 33 cc. I will get a picture of the entire kart this evening.
Pictures of the kart have been placed on my profile.
Atlanta, GA
With some fab work, an engine swap is very doable.
Remove the gas tank. Build a jackshaft set-up to 1)move the drive to the right, 2)deal with gearing issues. Insert 79cc or 212cc engine and roll out.
Chem- you can direct upload to this thread instead... Most people would apreaciate it..
I think the biggest thing is, will the new motor fit... There isn't alot of room..
Equally speaking... How much effort are you willing to expel to make the conversion and are you equipped to do so(welding cutting ect)...
nascarnation
Indiana
I bought a GK80 kart that had a Lifan 97cc 4 stroke on it. I swapped to a Predator because it wasn't strong enough to pull 70 pound kids up a pretty steep hill on my property. But it might be OK for what you're doing. They sell for about the same price new as a 212 Predator.
Another possibility is the "suitcase" 1800 watt gen sets use 80 to 100cc 4 strokes, maybe find one of those on the cheap used market.
