Prebuilt motor ?
pearl111
Baltimore, Maryland
Hi DIY has anyone here or know of anyone that has gotten a prebuilt motor from HOTRODMINIBIKE.COM ? I am thinking of getting their pre built Pro MOD Racing Engine Predator 212 -Stage 3 that puts out abought 15-HP.
I figured abought the price of parts, and motor and the time it would take for me to learn how to put it together correctly that just getting one already built would be the way to go. Their price for this motor is $799.95 not including shipping.
Any thoughts of does or don'ts on this issue would be appreciated.
THANKS.
Nosandwich
The REAL Poboy
WHITE SETTLEMENT
I would call GoPowersports and ask how much for a 15 hp 212 Predator. I've never heard of those other guys, but I've dealt with GPS. Mention you are a member here for a 10% discount.
I just seen somewhere selling a genuine Honda gx200 with some mods for $500
http://mud-skipper.com/index.php/motors/honda-gx200-modified-11-0-hp-approx-3-4-pto.html
Genuine Honda GX200, modified to 11.0 HP (Approx) and designed to fit The Twister Long Tail
With the standard 3/4" PTO, the GX200 mounts directly to the Twister Long Tail and features the following:
3/4" Horizontal keyed output shaft
Genuine Honda Flywheel
Genuine Honda Gas Tank and Muffler
22 lb Valve Springs
3 Angle Valve Job
230 Racing Series Camshaft
Dished Piston/Stock Rod
Removal of Governor
Large Fan
Advanced Timing
Rejetted Carb
K&N Style Air Filter
11.0+ HP (Approx)
Don't forget to ADD OIL TO YOUR ENGINE. Engine uses 5W20 o 5w30 Mobil 1
Honda GX200 Modified - 11.0 HP (Approx) - 3/4" PTO - Recoil Start - $499.00
Honda GX200 Modified - 11.0 HP (Approx) - 3/4" PTO - Electric Start - $798.00
22 lb Valve Springs
3 Angle Valve Job
Removal of Governor
Large Fan
Advanced Timing
Rejetted Carb
11.0+ HP (Approx)
I see they still have the stock rod but then use 22lbs valve springs??? With no governor??
Ya I think the Honda rod is better than a clone or Predator, but if you can do the work yourself...
For Under $510...
HARBOR FREIGHT
Hemi Predator 212cc.
$105 - $110
NR RACING
ARC 6256 Billet Connecting Rod
ARC 6626 Billet Flywheel w/32 BTDC built in ignition timing
Dynocams CM Grind Camshaft
22 lb Valve Springs (pair)
0.015" small valve spring shims (pair)
Hemi Predator Gasket Kit (comes with 0.010" Head Gasket)
Header (Keep it under $30 to keep on budget)
Muffler
$316.37 (shipping price to me included)
GOPOWERSPORTS
Intake Manifold
http://www.gopowersports.com/manifold-for-6-5hp-clones-predators/
$21.61 (shipped to me)
ALIEXPRESS
24mm Slide Carb
https://www.aliexpress.com/item/ZSD...0548-47cc-b476-a3ee7ee715e2&priceBeautifyAB=0
$20.40
TREATLAND
48mm Air Filter
https://www.treatland.tv/OKO-air-filter-p/oko-air-filter-g1-48mm.htm
$22
AMAZON
Pre-Filter
https://www.amazon.com/gp/product/B00KC641A2/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
$12.95
EBAY
Jet Kit
https://www.ebay.com/itm/10pcs-Carb...ash=item2a7b870e3c:g:3fUAAOSwWxNYqmYC&vxp=mtr
$6.93
Included rod, flywheel, camshaft, valve springs (with shims), carb (with manifold, filter, pre-filter, and jet kit), exhaust (with muffler). No throttle cable included above, which you would probably need to pick for your application.
But for $300, Predator 420cc are on Sale.
The discount doesn't cover performance parts from what I've heard, just axles, bearings, wheels, etc.
Yep, they sell a lot of parts at the same price the manufacturer offers to the public. Like a stage 3 performance kit will not get the discount.
---------- Post added at 01:47 PM ---------- Previous post was at 01:05 PM ----------
I think some of the AKRA racing classes turn 6700+ RPMs with stock rods on "improved" 10.8 lb springs.
They build their own performance engines. IDK about limitations on the 10% discount. They've never claimed any exceptions here.
If our forum discount is like some YouTuber ones are, then they are limited non performance parts. RGB has stated that his 10% does not cover performance parts.
pearl111
Baltimore, Maryland
After reading all the thoughts and ideas on prebuilt motors and I'm thankful for them they were helpful, I am still looking.
I've read up on the info and specifications on the Briggs+Stratton World Formula engine and I like what they have.
Has anyone had any experience with these motors? Any comments or suggestions?
Thanks again.
Panhead5496
Athens, Georgia
THANKS.
I ordered some parts from them, and they are a great company to work with! I had some questions and they promptly returned my email with a detailed explanation.
