Worth it to re-do a 212 Predator from gen set?
nascarnation
Indiana
A neighbor gave me a running gen set with a 2005 Predator 212cc engine. I'm wondering if it's worth converting this engine to a kart version (which I need for an old Manco I bought)? It looks like the engine side housing that mounts the generator is totally different than the kart housing that has an output shaft and 4-bolt pad. So at a minimum it's probably 30 dollars in parts, and does anyone know it the crankshaft is the same between the two - if not that makes it even more expensive?
I know it probably makes more sense to sell the gen set and buy a new Predator from HF.
anickode
S.E. Michigan
Crankshaft is tapered
Crankcase cover is different
Separate fuel tank
Fixed throttle governor
Larger more restrictive muffler (but much quieter) that needs additional support
And it's not a hemi head, so the availability of performance parts is more limited if you plan on modding it.
Is it really a predator? I didn't think they were called that in 05.
Either way, wait for a coupon and get a new in box hemi for $99
nascarnation
Indiana
Got it running with a carb cleanout...ran two 1500 watt heaters nicely... for 15 minutes...dropped an exhaust valve...off to the Boulevard of Broken Engines.
65ShelbyClone
SoCal
Isn't it the other way around? The "wedge" Predators were just straight Honda copies and there are still tons of parts for those.
anickode
S.E. Michigan
There are a handful of parts that can be interchanged between the two, but despite the similarities, they are different engines, and most parts like crank, rod, piston, cam, valves, etc, are different.
A true clone (the 196cc clones like Lifan, the old Greyhound engines from HF, etc) will share a lot more parts with a gx200
