Predator 212 Engine dies when switched to run
Eemownz
This is whats not switching
David Ham
Melbourne
Has the peoblem only just started? My first thought would be to screw in the idle screw a little but im sure someone will have a better idea as to whats wrong...
Sent from my SM-G900I using Tapatalk
You didn't circle the choke on that picture.
You circled the the lever that controls the throttle, not the level that controls the choke.
The governor arm will not switch the engine from choke to run,
You have to do that manually.
The governor arm is connected to the throttle, not the choke.
Eemownz
It started about a month ago before I moved I just now am getting the time to work on it
---------- Post added at 05:34 PM ---------- Previous post was at 05:34 PM ----------
What upgrades to the carb/exhaust aswell as the motor itself?..
It's still stock
---------- Post added at 05:41 PM ---------- Previous post was at 05:34 PM ----------
When ever I switch it to run it the intake side stays closed it works fine on choke but one it get put on run it dies
It sounds like the idle RPM is turned up too high.
If it is idling above the governed speed of 3600 RPM and you try to open the throttle, the governor won't allow it.
Try turning the idle speed down. It is a black plastic screw on the carb with Phillips-Head tip.
Otherwise, as always, check for leaks around the gaskets and disassemble and clean the carb.
Eemownz
I took the carb off and cleaned it a few days ago, I'm
Will mess with the idle tomorrow
Besides that, only thing I can think of is making sure the other end of the solid metal rod is connected correctly to the governor arm.
Also Check for leaks around the gasket area where the carb attaches to the cylinder head. Get it running and then spray carb cleaner around the gasket/insulator area. Listen for change in RPMs.
Sometimes the plastic insulator cracks or the gasket doesn't seal correctly.
