Jasonrk99
Don't recall seeing a 2-stroke vertical to horizontal conversion. Assuming you are converting it of course.
Yes, I'll just be rotating the engine 90 degrees so that it is then horizontal shaft. This can't be done with 4 strokes, because lubrication is then an issue. Picture #1 (below) shows the carb orientation when the engine is vertical shaft, such as on the mower it came off of. Picture #2 (below) shows what the carb will be like after rotating the engine for go kart use. Picture #3 (below) shows the carb orientation I will need for using the engine on a go kart. (I'm sure that if you're reading this you already know this lol).
My problem is the reed valve at the end of the plastic intake manifold. There are no bolts or even a gasket between the PLASTIC manifold and the intake port on the engine, just an o-ring . I thought I could rotate the manifold 90 degrees to fix this problem, but then the reed valve wouldn't open up into the square opening in the side of the engine (see picture #4 and #5), and even if I did manage to rotate it 90 degrees so that the carb is upright, the air/fuel would be hitting a solid wall.
So, I've pretty much come to the conclusion that the reed valve (circled in green in pictures #4 and #5) cannot be rotated and must stay like it is.
One of the biggest problems is that the intake manifold is plastic. If only it were aluminium...
Any suggestions? Know anyone on this website who has done something like this before?? I'm stumped and I can't really see an easy way out...
