Desertduler
- Messages
- 1,736
- Reaction score
- 14
Yes they are indeed.Man!! Those engines are beautiful inside
I know that you like these old relics partially because they are a invention from your homeland!Well, you got me drooling over those Wan'kel engines
(really that word censored is not to my liking...)
This little old computer struggles with html5 videos for some reason (well video ram buffer )..
long story short:
When I watch your videos I'm usually not logged in to diygk to comment directly,
and when back I usually forgot what I wanted to ask (the getting older thing and such)
But that doesn't mean I don't love watching you tear down these engines
(Know what... next time I'll take notes or you'll see me pop up on yt)
I too have found other engines with too short of a plug in them. Most certainly in a conventional piston engine you want to have the plug electrodes as close to the roof of the combustion chamber as possible if not protruding into it providing there is clearance between the plug ground electrode and the piston such as the case if the engine has a domed piston.I bought a minibike with a clone engine for one of my nephews. I pulled the plug and was surprised to see it was a shorty. I spent quite a while trying to figure out why they were using that plug. After finding no reason (the engine was completely stock), I replaced it with a longer one. The shorter plug has to bump up your chamber volume about a CC and like you said, with the shorter plug - the burn isn't going to be as good. Their mistake just meant free power for me when I corrected it.
Anyway, awesome stuff as always.
Super clean. Not what I would expect a 1974 'anything' to look like.
True, being too short is safer by all means and you are absolutely correct.I assume, that if one doesn't know what reach plug the engine wants..
one chooses a shorter one to be on the safe side
(not bumping the piston or in your case worse shredding an apex seal).
And that's why a short plug isn't too uncommon to see on used engines.
I guess there are as many "IDK what reach" that used a too long spark plug
but those engines end up at the scrap yard eventually
It's as easy as sticking a narrow wooden stick in the spark plug bore tilt it and measure the distance between the dents if your pinky isn't small enough to feel the threads on your own, I know;
but how many people do that when in doubt?
Yes indeed, too cold of a spark plug tends to foul easier.Kinda offtopic , but is it possible to have "too cold "of a sparkplug ?
Rotary engines i dont really like but are very interesting , and the rotor housing looks like brand new .![]()
Thank you for the kind words and the interest.Thanks for the vid. That was interesting
