Pics needed of a carter 2336 -3017
Wendle
Does anyone on here have a carter 2336 -3017 I need some pics of the drive side back wheel set up as far as brakes go
Karttekk
Elizabeth, PA
Normally one loop on the brake band goes around the brake rod going to the pedal and the other loop goes onto a welded stud on the kart frame. The band goes around the drum which is bolted to the wheel. There should be a return spring near the brake pedal also to help keep the band from dragging. Hopefully this is similar to your setup.
Thanks
Karttekk
Elizabeth, PA
Nosandwich
The REAL Poboy
WHITE SETTLEMENT
Take note that the rod is connected to the bottom of the brake band. Regardless of how you set it up,( some here have used cables), envision the fact that the frictional should try to close the band tighter, and not loosen it.
Wendle
Those are great I just need one from the top looking down at brake rod thanks
That is the correct way of mounting the brake band and it's actuator rod.
Image borrowed from Go Karts R Us!
THIS IS NOT!
Take note that the rod is connected to the bottom of the brake band. Regardless of how you set it up....
And that's why it's technically incorrect..
this way the friction of the band/drum is trying to work AGAINST the actuation of the driver.
(it's trying to loosen back up)
if it's mounted like in the first pic (the blue kart) the friction is working in your favour, not only slowing the kart, but also acting in the same direction as the actuator rod (pulling the band even closer)
Soooo.. both could work,
but the red kart needs a lot more pedal force for the same stopping power ...
Karttekk
Elizabeth, PA
The setup still looks like the basic setup explained earlier. The rod going to the pedal is going through one loop of the brake band and the other loop of the brake band is fastened to a stationary post or stud. Just a basic friction device that squeezes the brake drum when the pedal is pressed. Not a whole lot to those setups.
Thanks
