I was looking into compression ratio, camshaft profile, and head design for Positive Displacement Forced-Induction Engines.
CAMSHAFT
Most places suggest a mild camshaft (not too much duration 230 Intake, 245 Exhaust) with the single most important thing is extra (~10%?) lift and duration on the exhaust. The blower forces the air in, but the extra exhaust lift and duration helps get the air out of the cylinder.
Look for something with wider LSA (112 to 114) and little overlap (< 30 degrees).
Tighter LSA, or More Overlap (which helps scavenging at higher RPM), allows the intake charge to be blown out the exhaust.
I was thinking NR Racining's 280 series.
Lift: 0.280"
Duration (0.050"): 220 degrees
ICL: 106 BTDC
LSA: 111 degrees
With a 1.2 Ratio Rocker on the Intake and 1.3 Ratio Rocker on the Exhaust.
So 0.3384" Intake Lift and 0.364" Exhaust Lift, since I can't find a cam with more exhaust duration - I'll use the ratio rockers to get extra (and more rapidly opening) lift.
Have to work out max lift once the desired static CR is figured out and the parts needed to achieve that.
CYLINDER HEAD
-Focus on the exhaust port. Positive Pressure will help overcome minor restrictions in the intake port, but hogging out the exhaust helps get the air out of the cylinder (plus a wide free flowing exhaust).
-A multi angle valve job will help cool the valves.
I was thinking about a 22cc clone (non-Hemi) Head with 28.5mm / 25mm Valves.
COMPRESSION RATIO
The Bigger the combustion chamber, the better. Lower static CR means I can run more boost. More boost means more O2. More O2 means more fuel. More Fuel means more power. Low CR with High Boost makes more power than High Compression Ratio with Low Boost due to there being more O2 molecules present. Looking into Crank, Rod, Piston, Gasket combos that might give me around 7.5:1 Static Compression and try for around 12 lbs of boost. Or stock is around 8.5:1 and I could run 9 lbs boost. I was thinking about alky, figure the methanol will cool the intake, since there is no intercooler. Wondering how alky plays with the innards of the roots blower. I think Funny Cars use roots blowers and nitro? Or maybe I'll use 110 Octane? Or maybe water/methanol injection?
LOL - No fast and Furious, just Youtube - mostly Monty Car Mods.
