Noram Star Inboard Hub Direction?
jhuckstead
Can anyone tell me which way the shoe hub is supposed to go on a Noram Star, when it is mounted inboard?
Here is a picture it mounted the way Heeters told me, with the snap ring facing out, but I'm not so sure they understood what I was asking...
If you notice in the picture, the lead edge of the shoes look like they are scorching...
Joe-405
Enjoying New Projects
U.S.A.
If you keep posting in multiple spots and saying the exact same question over and over they will never answer. And we are all over the world so half of us are still asleep still ! Be patient little grass hopper and somebody will answer.
jhuckstead
Sorry, I posted in the wrong section the fist time and couldn't see how to delete it... Also, I am more than a little scared to ruin this clutch, because I don't have the money to buy another one.
I've never seen a clutch like that. But here's what my google fu found.
The internal mechanism looks like this, I'm assuming.
The shoe has to rise up on the angled slide.
The picture would be for counter clock wise rotation. If you flip the hub over and the ramps pointed the other way it would be for a clockwise rotation..
jhuckstead
Awesome, that makes total sense... I can't actually see the ramps because they are covered and the cover is riveted on... But I put the hub in a vice and pulled up on one of the shoes to see which way it moves... From what you are saying, I had it backwards! Thank God I second guessed it and asked. Thank you for the help!
I still can't find the origin of "Patience Young Grasshopper."
The internet says it was Kung Fu the TV show, but I've never been able to locate the quote. It bugs the heck out of me. I've spent hours looking for the answer, and know what? My patience hasn't paid off so far.:lolgoku:
I didn't change the hub or anything else around when I switched from running my Noram Star clutch from outboard to inboard. I simply installed the stock clutch with the drive gear facing in.
jhuckstead
The Star clutch has the drum and the shoe hub as separate and they do not attach with a snap ring... You have to use locking collars or bushings to keep them together on the shaft... The shoe hub is directional, but there are no markings on it or any diagrams in the box or on the website (for this clutch).
---------- Post added at 11:08 PM ---------- Previous post was at 11:02 PM ----------
The clutch grabs hard now btw... I just twisted my axle at the sprocket in 20 second of riding.... ughhh... fml
jhuckstead
I will will post an update with the picture of the axle and keyway when I get home.
Meanwhile... the plot thickens. Today, Noram sent me a diagram that shows that the angle arm hubs like this are bi-directional, and produce different torque and engagement speeds depending on the orientation...
Here is a picture of the diagram they sent me. I sent back the picture of my scorching shoes and I am waiting on a reply...
jhuckstead
Here is the axle... The pics don't do it justice... The sprocket was wobbling so bad it threw the chain.
What does the hub and key look like?..... That keyway looks off a bit ya... but not twisted... Ive seen far worse...
jhuckstead
The hub and key look fine... the axle has an ark and it hops when rolled on the floor... it maybe only 3/16", but that is enough to slack the chain and throw it of...
It actually bent twice, I hammered it straight and put it back and it bent even faster the second time... by how easy it hammered out, I can tell that it is crap steel. It came with the kart frame I bought used and it has a double step down. The metric measurements are roughly 1" to 3/4" to 5/8" (26mm to 20mm to 16mm).
I am going to swap it out for a 1" to 5/8" custom axle from bmikarts... hopefully the longer 1" length and being 1" thick instead of 3/4" thick where the hub mounts will give it the strength it needs.
Unfortunately the axle bearing housing is only 42mm just little bigger than 1 and 5/8", so I will have to run 5/8" ID bearings on the stepdown...
I debated replacing the bearing housings and running a straight 1", but that combined with the price of new wheels is just too much for me.
