Ken
The Greyhound clone has only run for a few hours. Changed the break-in oil, removed the governor, put an aftermarket throttle linkage, cone air filter and wienie pipe. Starts great but misses at WOT and will stall if you release the throttle suddenly. I checked the sparkplug for evidence of a fuel mixture problem but it's nice and tan. No soot or white coating so I think the OEM jet is fine. Plug gap is correct so there has to be something else in the ignition.
Can the flywheel or magneto degrade over time? The engine did sit unused for 4 years since new before I recently started it. Flywheel has some flash rust, but perhaps I'm missing something else obvious.
Open to any and all suggestions
