If I understand you correctly, by doubling the HP you also double the torque. Somehow I thought you got less of a torque increase for any given HP increase.
How about this one - would a 12:1 gear ratio get you roughly twice the initial acceleration as a 6:1 gear ratio or is the relationship not a straight line? In other words, all else equal, would you go 0-10mph in half the time?
I'm probably opening a can of worms and really showing my ignorance with that one.
If it's too much to bite off that's fine.
I'm just hoping this engine, once completed, won't have much slower acceleration. That would just really **** me off. I'm aiming for a top speed in the 30-35 mph range so I might nudge the gear ratio up a little. Not sure how many RPMs this thing will pull.
No, no and no
with some yes spread in.
We talk strictly industrial engines here "in general" not specifically
a certain mod or engine...
NO you do not double the torque if you double your hp
since most of that hp is coming from increased rpms mostly (governor removal passing valve float and such.
since power is torque times rpm (well speed actually but for an engine that IS rpm!)
the higher the rpms the less torque you
need to get hp.
with JUST increasing rpms (remove governor, allow to breathe freely no other mods)
you increase rpms but you do NOT increase or decrease max torque
since torque values describe a bell curve it drops at higher rpms again
which means although your hp at 5000 rpms is bigger than at 3600
chances are you still have LESS torque at the higher rpms.
shifting timing moves the torque curve slightly, different cams do that as well (some even increase the torque slightly)
a higher compression ratio also increases torque..
a combination can do all sort of things in between and beyond
No, doubling the ratio would NOT automatically double the acceleration.
it's FAAAR more complicated than that, as I said torque is NOT linear, it's a bell curve.
so acceleration itself is not linear (far from it tbh)
But here's the thing, if you mod an engine properly (you can mess things up of course... but let's assume you do it right, shall we?)
you increase either hp or torque or maybe even both.
no matter what the performance of the engine will be BETTER!
and with a bit of adjusting you can make use of that increased performance.
So much slower acceleration is just not going to happen.
(once gearing is properly dialed in to your new power curves it'll certainly be a quicker acceleration!)
