Just impulse bought another go-kart.... and it doesn't work. :| help!
isuckateverything
im an idiot, i know
NYC
Clean the carb
carb was literally just replaced with a brand new one.
---------- Post added at 01:55 PM ---------- Previous post was at 01:54 PM ----------
What happened to all that resistance you had in the pull cord?
New carb on?
it comes and goes, but now i pull it with a glove on so it doesn't tear my skin if it does happen.
but the main issue is it not holding an idle, is there something to adjust to fix that? or is something probably wrong with the motor itself.:huh:
jandj
Williamsburg, Va
He's bypassing the pulse pump with a gravity feed tank.
Will the engine continue to run if you leave the choke on?
---------- Post added at 02:17 PM ---------- Previous post was at 02:06 PM ----------
What happens if you let it run for a few minutes to warm up then turn the choke off?
And just out of curiosity, where does the pulse line from the valve cover go now?
Dustin2017
SPP_MN
Sweet home Oregon
Is it just me but it looks like his tank sits low like the fuel has to try and travel uphill.when it’s running before it dies does the fuel filter still have fuel in it and how’s the float level ?
When the engine dies, turn the fuel switch to "OFF", then crack the drain on the carb bowl to see if there is fuel in the bowl.
The choke is cutting off AIR when turned to START, which makes the mixture RICHER.
Turning the choke to RUN, makes the mixture LEANER (compared to Choke on START) by allowing more AIR through the carb.
The idle mixture screw (if you have one) will have a head for a FLATHEAD screwdriver. It will be a FUEL screw. FUEL screws meter how much FUEL at idle. Turn the screw Clockwise to reduce FUEL (make the idle mixture LEANER) or turn it Counter-Clockwise to allow more fuel (make the idle mixture RICHER)
It seems like the idle circuit is acting LEAN, meaning too much AIR or not Enough FUEL.
You can try to turn the idle mixture screw to 3 turns out.
Gently turn the screw clockwise until is seats. If it is less than 1 turn to seat it, it is turned in too much. Be careful with it, don't damage the tip of the screw. After it is all the way in, then turn it counter-clockwise to back it out 2-3 complete turns. See if that helps. More turns out will make it RICHER
Also let it warm up a bit before switching to RUN.
And check for leaks around the carb gaskets and adapter. When it is running on choke, spray carb cleaner near where the carb meets the cylinder head. Listen for a change in RPM, or maybe it will die if there are leaks and you spray carb cleaner or starting fluid.
Or maybe a sheared flywheel key? My new favorite solution. LOL
Maybe Timing is OK for rich choke mix, but maybe the ignition shifted too advanced for the leaner RUN mixture.
I don't know. Hope any of this helps.
jandj
Williamsburg, Va
What I see in the video:
He shows us the gas is on.
He puts the choke on.
It starts on the second pull and runs.
He blips the throttle a few times, the engine responds.
He turns the choke off.
The motor dies.
All this in 10 seconds.
Could be as simple as the idle screw not being set right.
Hard to diagnose anything from the video.
I know my hot rod blue clone needs more than 10 seconds of run time before I turn the choke off.
jandj
Williamsburg, Va
I was wondering when someone would mention that...
OP asks that question in his video. He asks whether he should be adjusting either one of the two screws on his carb.
He might also try turning up the idle RPM speed a bit just to see if that helps.
jandj
Williamsburg, Va
He might indeed.
If only there was somewhere he could have found a picture that explains what's where on his carburetor.
Then again, it may be the oil....
---------- Post added at 07:46 PM ---------- Previous post was at 07:02 PM ----------
Kidding aside, let's break it down.
1-Won't run without the choke on.
1 A- Could be running lean.
2-Why would it be lean?
2 A- Might be sucking air. While it's running, spray around the carb/manifold area with carb cleaner, instant start, etc. Do the rpms change?
Yes - Repair the leak, most likely the gasket.
No- On to the next step.
3- While it's running, turn the idle screw in half a turn before turning off the choke.
Does it stay running?
And so on....
Going at it in a step by step method rather than diving into the innards of the carb may save some time and trouble.
Keep it simple stupid...
When it comes to noobs, for the most part, we have no idea of their experience or abilities so, we need to assume they have none & start with the basics that the more experiences among us would overlook...
isuckateverything
im an idiot, i know
NYC
thanks, this is very true.
i'm the noobiest of noobs, but i sorta understand what my next thing to try will have to be, i have to adjust the idle screw.
will update soon if that works, it's freezing in NYC and I haven't been to motivated to go outside and ride this thing yet :yawn:
KingCobra
TROLL CRUSHER INC.
TROLL TORTURE ROOM
He wasn't referring to you with that first sentence, but to someone posting a lot of blah blah and repeating of the same suggestions like an echo, so don't be sad........ :D
Karttekk
Elizabeth, PA
If you're comfortable with disassembling your carburetor or know someone who is, these Gunk carb cleaning kits/dipping buckets are a great option for thoroughly cleaning out carburetors. Once the carb is off, remove the fuel bowl with I think a 12mm wrench, unscrew any jets, remove the float, needle and seat and any rubber gaskets then dip the whole carb in the bucket for the time specified in the cleaner instructions. After removing the carb, spray it down with carb cleaner and blow out the jets and any small holes with a low pressure air hose. Reassemble the carb and install with new gaskets. Certainly can't hurt and this will get to any clogged ports that aren't accessible. Good luck!
Thanks
https://shop.advanceautoparts.com/p/gunk-carburetor-parts-cleaner-complete-kit-cc3k/7040709-P
jandj
Williamsburg, Va
He's got a new carb on it.
The last we heard from him, it'll start but won't stay running when the choke is off.
Could be several things but we haven't heard from him in awhile.
Maybe he went in the garage and froze.
isuckateverything
im an idiot, i know
NYC
haha, i appreciate your advice and help, i'm pretty sure it's the idle screw.. the real reason i haven't update any of you is because it's been under 30*F out every day since a few days ago in NY and it makes starting the kart a pain in the ***...
i'll wait till tomorrow when it should hit 50*f (somehow lol) and try adjusting the idle screw with your nice picture instruction :)
also, i've just been busy drifting the other cart in snow :D
https://www.youtube.com/watch?v=TjYQ2mSEh0A
p.s= i wish i had a shop or warm place to put the karts in, but i don't, so for now, they're outside in the freezing cold with a heavy duty tarp over em :[
maybe in the future, also, it makes starting them in cold weather ridiculously hard, took me over 15 minutes of pulling (at least 100x) to get it started for that video above :{
