gr8hairy1
.... that issue.
How much room do you have in front of your engine?
Not much at all... maybe a few inches.
I am very jealous of the replaced rear swing arm that kevbo22 posted. So much room to do whatever you want!
.... that issue.
It came out pretty good, thanks.
Its not so roomy any more however. I put in a FNR gear box, and with the 40 series, brake caliper, hub and disk and battery box, it pretty much eats all the room up.
But it works great.
Wow oh wow forget my silly ideas. That is hands down the best setup. Even if I could fiddle with the design and get something to work, I know I'll always be wishing it was setup like yours. Definitely would need a redesigned swing arm like yours to fit the height of the jackshaft box (such an obvious idea now that I know about it).
So....uh.....did you make it yourself? Usually doing it the first time is the hard part, making something the second time is easy and quick![]()
Kevbo22
Thank you such for the info. I don't think I'll be able to convince myself to go any other way than what you did.
How did you keep all the connections in the same place but still have the clearance for the jackshaft box and the extra room above the engine?
By the way, what gear ratios are you using?
Any piece of 1" keyed shaft will do...
Could get fancy with one with threaded ends, but the above will be just fine...
Get plenty of shaft collars for the wheels and such...
Does anyone have any recommendations on where to get an axle this go kart? I'm not sure what I'm supposed to be looking for.
Go 44" X 1 1/4" Seek out wheel hubs for the 1 1/4" axle first to make sure you can find them. Plan ahead and then after your research is completed and you can assemble the axle you want, then order it.
A quick search on your sprocket... It is a JT sprocket... They are at least relitivly common... Now you just need to find your bolt pattern and desired tooth count...
As promised in our PM, here are the dimensions. I couldn't send the image via PM, so im posting it here. Hope it helps if you decide to go this route.
Ebay will have great deals and you will need at least a 42". Go 44" X 1 1/4" or 1" if you must. Seek out wheel hubs for the 1 1/4" axle first to make sure you can find them. Plan ahead and then after your research is completed and you can assemble the axle you want, then order it.
Good advice! Thats exactly what I used:
http://www.bmikarts.com/1-14-Tubular-Steel-Axle-14-Wall_p_510.html
I picked this axle just because of what you said!
http://www.jtsprockets.com/catalogue/sprocket/JTR810/
Also Wally World has a 53T version that should fit:
https://www.walmart.com/ip/JT-Steel...4411&wl11=online&wl12=556340414&wl13=&veh=sem
