Would you... 60 or 72 sprocket
So I’m putting a 30 series torque converter on my Baja Warrior MB200 and currently it has a 50 tooth rear sprocket it came with and the TC has a 10 tooth 420 pitch. Now at GoPower Sports they have either a 60 or 72 tooth tear sprocket I can get, and I am leaning toward the 60 which will give me a 6:1 ratio. Seems a little low but will that work with a 30 series and not burn up belts. Also worth mentioning the rear tire is 19” and while I wouldn’t mind the 72 tooth I don’t need a wheelie monster but a nice trail bike.
Here is the sprocket I’m thinking of.
http://www.gopowersports.com/4-hole-mini-bike-sprocket/
Thanks,
—Dan
I'd say with governor use a 60, no governor - use 72.
I think you can find a 60T cheaper than $60.
I tried to google it and I may have missed them but do you have a link to one that would fit. I measured and this one should fit.
I still have th governor don’t plan on removing it.
—Dan
Tpdingo
Bellmore, NY
Me, 10" tires and 36t sprocket.
That clutch will spin right round like a record then go BAM! Basically a DIY grenade!
Slimmpd
Calera Alabama
Got a Manco big cat, hf 212, 8-80 geared with a 30 Comet. Huge tires, 22x11x8’s. The bike weighs a little over 200 by itself, I’m 260. This bike will lug at 3 or 4mph on the flats and a little over 20 when you kick it. For a off road bike it’s a hoot. With those gears there is not much those big tires won’t claw up and 20mph is pretty fast on single tracks.
Nosandwich
The REAL Poboy
WHITE SETTLEMENT
Haha haha haha....yeah...NO.
NUF SAID. Better to remain silent.. We don't like to chunk around bad info here, ...even in jest. We all know he just needs more jackshafts.:roflol:
