I'm no longer convinced it's the backplate tbh..
Comet lists both (the tav2 kit and the series 30) as 8hp in official documents
I think the main culprit is the belt.
In the end, for the belt to work it needs to slip,
the more it slips the warmer it gets, the warmer it gets the more it'll slip.
if it slips it wears and if it slips badly it wears badly..
the more torque you have the more it slips...
you see where this is leading, no?
neither the driver nor the driven would care much about torque at first..
they hold up to a certain rpm.. and they're design to be under load at that rpm...
I doubt you can reach their threshhold and get the driver to desintegrate.
but it'd be funny to see the driver w/o load spinning at 16k rpms on a 15hp two stroke just for the record
Anyways.. it's still the belt being the weakest link.
Since supermannotorious has the Tav2 on at least a few 420 predators.
we can safely assume for non karting situations it's still good enough for 13hp
And while some people are okay with a belt lasting only a few months while other want it to last for 2 or more years...
how should we put a limit on that?
torque hours per belt (for certain manufactier and length)??
*shrugs*
