Low Top Speed
npragin
Hey guys, I am new to karting and don't have much experience and, I am making plans for building a go kart with my friend, and I have picked my engine, wheels, tires, torque converter, and the jackshaft sprocket, and my drive wheel sprocket. I am using a Honda GX200 engine, and my drive wheel sprocket is at 72 teeth while my jackshaft sprocket is at 12 teeth. I am using a Comet 30 series torque converter, and my overall diameter of my wheels with tires is 10". When I use the speed calculator on here it is telling me that my top speed will be 18 miles per hour. I was under the impression that the average speed of a kart is about 30-40 miles per hour. I am wondering how I can bump up my top speed. Thank you.
What is the end speed you are trying to accomplish?
You can make the rear sprocket smaller, front sprocket bigger and use bigger tires. Assuming you have a 3600rpm governor intact you can go to 60 tooth sprocket on the rear and that will give you 23mph (assuming TC overdrive). This will be a 5:1 ratio in the end. If you remove the governor you can hypothetically get 33mph but the internals of the engine may need some re-enforcement.
I can tell you my gokart goes about 35 according to the phone GPS and that feels absolutely fast enough when that low to the ground. Personally about 33 is perfectly enough.
--Dan
npragin
How can I verify that my torque converter is in overdrive? Also, how much bigger should i make my wheels to achieve the 33 mph? Also, what width for my wheels would you recommend? My front wheel width is 5 inches, and my back is 8. I think that's a bit much and wanted to hear your take.
a series 30 TC will be in overdrive as soon as it can.
you cannot verify that at all other than by measuring the speed and making the calculations backwards.
doesn't matter.. there's just 1200-1400 rpms for you to work with
(from clutch fully locked @~2200rpms to governor kicking in @~3600 rpm)
engines like that are pretty much on or off really.
a governor removal adds about 2000 additional rpms to your engine and of course increases the speed while doing so :D
If you are using the 30 series then you have the 1.1 (I believe) ratio overdrive.
Sprockets staying the same and the governor in tact you will need 18" tires to get about 35mph in overdrive (33*1.1). Removing the governor about 12" tires which will be about 33 mph (30*1.1).
Me personally I would remove the governor and re-enforce the internals (billet rod/flywheel) but that is quite a lot more money and get some 12in tires. I am also assuming you are using a Honda/clone engine. Once the governor is removed leaving everything else same you are looking at about 34mph top speed. I may be in the minority here but that quite fast for a kart unless you are talking about a racing kart.
--Dan
npragin
To reach the 34 mph would I have to re-enforce the engine? What would that change and why is it necessary? I'm new so I'm not completely sure.
If you were to remove the governor only. A good idea is to change the rod and flywheel to billet and get some stiffer springs. However I have been running my predator 212 for about a year and a half with no governor and stock internals (only using valve float as a "governor" of sorts) and so far its chugging along. No sign of it going bad however I am taking a risk that at some point it will have a failure but oh well.
--Dan
No governor, 10" tires, 30series TC with 6"Driven Pulley (0.9:1 overdrive) 12T TC Sprocket, 60T Rear sprocket, Advanced Ignition Timing?, 5200 RPM, 34mph
Or slap a 54T on the back with the 12T and see if you can hit 38mph.
Or keep the 72T and swap the 12 with a 14, 15, or 16T.
The bigger JS sprockets might be "B" type vs "C" type... Might have to adjust alignment.
I've used "B" Type 8T and made it work, but haven't tried any other ones.
https://www.ombwarehouse.com/-35-chain-16-tooth-az2130.html
npragin
Final question, are my tire dimensions ok? I am going to upgrade the overall diameter to 12" like you said, but are the widths alright? My width for my front is 5 inches, and for my back is 8 inches. Is that alright or should I make some changes.
---------- Post added at 12:02 PM ---------- Previous post was at 11:58 AM ----------
bob58o, are you saying I should advance the ignition timing of my engine, or that my engine already has it?
Don't need bigger tires unless you want them. You can gear it with no governor and those tires to reach your desired speed. Stock ignition timing is like 24, advance it a few degrees to shift the power higher in the RPM range.
Staff Murderator
I would like to add in Adjusting the Governor, for a higher top end or a redline so to speak.
No need to eliminate it entirely.
In a collective sense and for the forum's edification, I would love to see this method "fleshed out" and explored, especially on a Honda GX...
Joe-405
Enjoying New Projects
U.S.A.
I think personally he would be money ahead to just go ahead and get the arc $100 flywheel which has the advance already built in to the keyway.
Nosandwich
The REAL Poboy
WHITE SETTLEMENT
First of all...let's not forget a flywheel is OPTIONAL .
Second, when did this site become OMB, (sometimes referred to as OMG!) Touch an engine, and it has to be billet EVERYTHING!
YEAH, even one poster, ( who was pushing billet internals, ADMITTED he had been running on stock internals.. since Mt. St. Helens,....but MAYBE, MAYBE, He's living on borrowed time. :smiley_omg:
Sooo... let's spend $300 to save a perfectly fine running $100 engine....glad you aren't my broker.
We are not OMB, and we don't really care whether you buy billet or not. It is just suggested that when you take the governor out AND GET STIFFER VALVE SPRINGS, that it is a good idea to get a billet flywheel and rod. This is only because the stiffer springs means that your engine is not being governed by "valve float" anymore.
Tere have only been one or two cases WITH EVIDENCE, of an engine having a catastrophic failure due to the lack of billet parts. IMO, there are too few failure stories for me to be worried about people not needing billet stuff. Just be aware that it COULD happen though
And no.....you will never get banned, warned, chastised etc on this forum if you don't use billet. It is just mentioned because we care about safety. It is definitely OPTIONAL though
Nosandwich
The REAL Poboy
WHITE SETTLEMENT
Well, my point was, not everyone has to go nuts altering a Chinese industrial engine. They work pretty well, and can be made to work even better, with almost no money.
So, to really talk about safety; let's look at the ELEPHANT in the room. It's not whether a shiny billet piece of carp will save an engine. It's this insatiable obsession with SPEED. Karts don't have to obtain life threatening speeds to be fun.
npragin
So just to be clear if I do remove the governor and bring up the ignition time, I would definitely need stiffer valve springs? Or are you saying if I get stiffer valve springs as well as do the other two things I should get the billet.
You can remove the governor and swap a sprocket and be fine. The stock valve springs limit RPMs to speeds where Con Rods and Flywheels generally don't come apart. Advancing the timing still doesn't change that RPM limit, but if you aren't reaching valve float RPMs... Advacing the timing will shift power from lower RPMs to higher RPMs allowing a higher max RPM and higher top speed (at the expense of some low end power, but you've got a TC so that is a low end multiplier).
Swapping in stiffer valve springs allows more RPMs. At these RPMs, Con Rods will come apart.. And at higher 7000+ RPMs, a flywheel or two has exploded, but not very often. Stock springs means no need for billet parts
