Go karts. With. Motorcycle engines
Chuck1
WA. USA
Hi
I am looking fot info on karts with motorcycle engines (fzr 600) trying to figure out. Stater to rectifier (3wires to 4post 1hot) it is a 92 engine.
Respectfully
Chuck
MTNSleder
😈 Snake ƘƖԼԼЄ&
USA/CANADA
Hello welcome.......
Maybe some pictures of your problem will help us help you...
easiest way is to google for the wiring schmematics of the motorcycle in question.
(best the exact year and model) then you not only know where but you also know what color ;)
But, any fzr 600 that's reasonably close (not a decade younger/older) should do.
PS since when does all wires of the starter are wired to the rectifier?? (simple anser: they don't!)
the rectifier has two IN and two OUT terminals, AC comes from the alternator and is (hence the name) rectified to DC power.
Those two are more often than not red and black sometimes orange and black
(alternator usually uses brown and white sometimes brown and blue or alike)
Anyways, a multimeter (set to DC Voltage) should tell you for SURE which one is which,
but only if the engine is running..
the smae Multimeter set to DIODE test can tell you how the diodes are facing inside and that works well with a non running engine and no power at all ;)
So.. just use a multimeter to find the DC lugs on the rectifier.
Now...
those two wire straight to two wires on the starter (plus on plus, minus on minus... straight forward, ain't it?)
the last (usually a bit thinner than the other two) is the solenoid switch.
that's wired straight to the starter button. (that's again a 12V+ signal.. but much less amperages needed to power the solenoid ;))
button pressed, solenoid closes, starter runs.. button release, solenoid openes, starter disconnects ...
done
Chuck1
WA. USA
Hi
Thanks for the info...
Mext... I have a turbo kit for a ATV. I plan to install with a dynatec 2000 CDI Airamotive FP and a standalone oiling systam.
Any ideas?
Respectfully
Chuck
carbidecutter
First I'll say to the moderators, If I'm not allowed to do this please delete... there is another forum dedicated to carts with motorcycle engines (minibuggy.net). They helped my nephew get the correct wiring for his sand rail he's building.
I didn't catch it at first, but it might have been moved... I don't see anything wrong to continue, but provide more info and pics...
You are more than welcome to post here!! We like all types of vehicles. Anything with an engine :D
